plasmac message error
5 years 10 months ago - 5 years 10 months ago #193030 by beauxnez
Replied by beauxnez on topic plasmac message error
Thank you
I removed -not
Last edit: 5 years 10 months ago by beauxnez.
5 years 10 months ago - 5 years 10 months ago #193238 by beauxnez
the herocut 55i works well for the moment no bug at the computer level to succeed in making it work I must simulate arc Ok with an interuptor because if not I have an error message arc valid signal lost
you need a pull resistor up or other on the arc exit Ok on the herocut?
5 years 10 months ago #193243 by tommylight
Replied by tommylight on topic plasmac message error
The torch should be up before starting a cut. Having it low will void the probe speed and run it at setup speed.
5 years 10 months ago #193252 by phillc54
Replied by phillc54 on topic plasmac message error
tommylight wrote: The torch should be up before starting a cut. Having it low will void the probe speed and run it at setup speed.
+1.
See the third sentence: linuxcnc.org/docs/devel/html/plasma/plas....html#_using_plasmac
I have been giving some serious thought to having the filter program automatically place a Z move to just below the max height for the first cut.
The following user(s) said Thank You: tommylight, snowgoer540
5 years 10 months ago #193282 by tommylight
I would not bother with it, on machines with limit switches it is not an issue, and adding the "material 0" button takes care of that. I use a laser for material edge finding so i have to use that feature. Although adding a G53 Z10 or simillar to the top of the gcode should also do.
5 years 10 months ago - 5 years 10 months ago #193288 by snowgoer540
Replied by snowgoer540 on topic plasmac message error
phillc54 wrote: I have been giving some serious thought to having the filter program automatically place a Z move to just below the max height for the first cut.
I'm a fan of this. My touch-off button is modified to have a G53 Z0.196 so that when I zero X and Y I dont forget to jog the torch back to the top.
It seems it would save a lot of new users a lot of headache.
Last edit: 5 years 10 months ago by snowgoer540. Reason: Fix quoting
Time to create page: 1.352 seconds
