QtPlasmaC release.
31 May 2022 10:46 #244274 by tommylight
Replied by tommylight on topic QtPlasmaC release.
If you have "Soft Keybord" selected in the PARAMETERS tab then when you tap the entry box in the MDI panel the soft keyboard should appear. Is that not happening?
Yes it does, but sometimes it does not, i chalked that to having the other soft keyboard installed and active.
Maybe they are fighting each other ... :)
  • phillc54
  • phillc54's Avatar Topic Author
  • Platinum Member
  • Platinum Member
31 May 2022 11:03 #244275 by phillc54
Replied by phillc54 on topic QtPlasmaC release.
They shouldn't be but ya never know.
Tomorrow I will set Onboard as the keyboard for MDI. Would it be best if it appeared immediately the MDI screen was showing or wait until the MDI entry line is tapped?
31 May 2022 13:31 #244289 by tommylight
I would set it to immediately, saves the confusion and wandering. :)
  • phillc54
  • Platinum Member
  • Platinum Member
01 Jun 2022 02:34 #244339 by phillc54
I have pushed the change for this.
13 Aug 2022 19:13 #249667 by Samas322
Replied by Samas322 on topic QtPlasmaC release.
Hi i just made an update and now i am unable to use qtplasmac! also pncconf disappeared. it is throwing me this error.
File "/usr/bin/qtvcp", line 511, in <module>
APP = QTVCP()
File "/usr/bin/qtvcp", line 277, in __init__
window.load_extension(opts.usermod)
File "/usr/lib/python3/dist-packages/qtvcp/qt_makegui.py", line 265, in load_extension
methods, self[obj].handler_module, self[obj].handler_instance = self._load_handlers([handlerpath], self.halcomp, self[obj])
File "/usr/lib/python3/dist-packages/qtvcp/qt_makegui.py", line 293, in _load_handlers
mod = __import__(basename)
File "/home/ssm/linuxcnc/configs/by_machine.qtplasmac/qtplasmac/qtplasmac_handler.py", line 51, in <module>
from qtvcp.lib.qtplasmac import run_from_line as RFL
ImportError: cannot import name 'run_from_line' from 'qtvcp.lib.qtplasmac' (/usr/lib/python3/dist-packages/qtvcp/lib/qtplasmac/__init__.py)
can some body help me as fast as possible please! is it possible to downgrade to an older version of QTplasmac or repair this error fast? my cnc table is unusable now because of this error and i have jobs to do! thanks everybody for help!
13 Aug 2022 19:18 #249668 by snowgoer540
Replied by snowgoer540 on topic QtPlasmaC release.
Nothing changed on our end (qtplasmac) that would cause this, and qtplasmac is working fine over here.  Seeing that pncconf is missing, I am guessing something got deleted accidentally.
Are you running a run in place build?  Or a package install?
13 Aug 2022 19:19 #249669 by Samas322
package install.. what is the difference of this?
13 Aug 2022 19:25 #249670 by Samas322
also if im looking at the last file specified in the error message: _init_.py
it is all empty..
13 Aug 2022 19:26 #249671 by snowgoer540
Not sure as far as why one works and one doesn’t currently, but they were doing work on the package install stuff so something may have broken it.
I run a run in place version, was also going to explain how to downgrade if you were on run in place.
I’m not home so I can’t do any investigation right now.
You can downgrade by downloading one of the earlier packages from the buildbot site and installing it manually. You’ll have to search for examples on here of how to accomplish that.
13 Aug 2022 19:31 #249673 by snowgoer540
You could try reinstalling it in the package manager. (Backup your config folder someplace like your desktop just in case). Mark for complete removal, then install.
Come to think of it, I think there’s a way to downgrade from there too.
Time to create page: 0.954 seconds
