QtPlasmaC release.
- Samas322
- Thank you received: 10
15 Aug 2022 11:14 #249767
by Samas322
Replied by Samas322 on topic QtPlasmaC release.
Yes pncconf is not visible in the menu.
And yes i asked for 2.9 version as stable.. ok no problem.
- Thank you received: 7490
15 Aug 2022 11:59 #249770
Replied by tommylight on topic QtPlasmaC release.
Check the "accesories" sub menu, LinuxCNC stuff would end up there sometimes.
- phillc54
- Thank you received: 2100
15 Aug 2022 12:03 #249773
by phillc54
Replied by phillc54 on topic QtPlasmaC release.
Nah, it is not there either Tommy. Latency Test is though and it also appears under Documentation...Check the "accesories" sub menu, LinuxCNC stuff would end up there sometimes.
- phillc54
17 Aug 2022 23:58 #249983
by phillc54
There are still some oddities that are being worked on but most menu entrie are there somewhere...
The latest version now has it showing.Yes pncconf is not visible in the menu.
16 Feb 2024 23:53 #293558
Noticed a strange issue today, using Debian 12.2 with 2.9.no idea as i am not in the shop now (1AM here), not updated for at least 4 months, so i will try to explain steps to reproduce it:
-the usual, start, home, move to some place on the table
-press F9 - all good
-ONLY if the torch does not reach the material, like between slats, it retracts and sends the error - all good
-now nothing works, no jogging, no F9, no motion, Start button flashes
-pressing ESC several times gets out of this condition, mostly, twice it did not had to disable/enable to get out
Anyone else can reproduce this on the latest version?
- phillc54
19 Feb 2024 02:26 #293736
by phillc54
I have not been able to emulate that issue but I did see that if a manual cut did not detect the material and then the cut was aborted, you could not start a new manual cut. I have a fix in the works for this.
- Franklin
- Thank you received: 19
19 Feb 2024 22:34 #293798
by Franklin
Replied by Franklin on topic QtPlasmaC release.
Hello, I noticed one bug in the cutting recovery mode, when I moved the torch using the arrows and pressed CANCEL MOVE, and then pressed the button to CYCLE RESUME, the program continues to move without probing.
- snowgoer540
- Thank you received: 907
19 Feb 2024 22:37 #293799
by snowgoer540
Replied by snowgoer540 on topic QtPlasmaC release.
Could you tell us what version you are on? It’s in the window’s title bar.
- Franklin
19 Feb 2024 22:48 #293802
by Franklin
I am using v2.10- 003.023
This bug was also on previous versions, I follow updates and try to always update my machines.
- snowgoer540
19 Feb 2024 22:57 #293804
by snowgoer540
No worries, since v2.9 and v2.10 have diverged significantly, it's best not to assume anything on our end
I do see the bug here. Phill or I will work up a fix and push it ASAP.
Thank you for the report!
Time to create page: 0.164 seconds
