QtPlasmaC release.
- phillc54
- Thank you received: 2100
19 Jul 2021 07:33 #215289
by phillc54
Replied by phillc54 on topic QtPlasmaC release.
I run a lathe, a mill, a plasma table, and assorted test configs from one PC so using the last config in autostart would be silly.
- Thank you received: 4152
19 Jul 2021 08:58 #215296
Replied by rodw on topic QtPlasmaC release.
Perhaps, but you are not replicating what I assume Tommy is doing. His words autostart are quite ambigious.I run a lathe, a mill, a plasma table, and assorted test configs from one PC so using the last config in autostart would be silly.
- phillc54
19 Jul 2021 09:04 #215298
by phillc54
If you look at the linuxcnc script, it seems to do the same thing either way.
- Thank you received: 7490
19 Jul 2021 10:33 #215308
Replied by tommylight on topic QtPlasmaC release.
I am using Mint 19.3 on all machines, so maybe something there ...
Thank you for testing this, but this is not a problem at all since it happens only as described, and i always have backups.
As luck would have it, found another much bigger issue that did happen 3 times till now, usning shape wizards to draw some shapes, delete, move, multiply etc, after about 5 minutes of messing with it it will lock QtPlasmaC solid!
This happens only when using it a lot when showing clients what it can do, so ends up not a good show!
- snowgoer540
- Thank you received: 907
19 Jul 2021 11:21 #215312
by snowgoer540
Replied by snowgoer540 on topic QtPlasmaC release.
I will say, Phill talked me out of Mint months ago... Maybe a year even now (time flies), and any stability things I had went away. Also at the time Qt wasnt always sending error message popups consistently. Never got to the root of that, but MX Linux hasnt had any issues, and it's snappier, loads faster, etc. I highly recommend.
Two questions:
1. Do you have steps to reproduce the conversational issue? I've spent a ton of time in the conversational trying to break it in every way possible, and I've never had it completely lock up. But as your friendly local test pilot, I'd love to break it if possible
2. How did you make out with the new configs or taking out the plasmac.thc-feed-rate setting from your hal files, etc?
Two questions:
19 Jul 2021 17:13 #215330
It is not locking, it is just ignoring my stupidity as i am trying to go to the main screen without adding the last parts of the drawing and sending it !
I'll go hide under a big rock for a while ...
There were some old Russian made rockets also ...
Some fun, finally, and i did ask if i can beat the tip of one of them with a hammer! It was a resounding NOOOOOOO !
I just tried to reproduce the procedure on a sim, and i could !
Not yet, had to much people last few days causing to much distractions, but i was staring at a sidewinder and at a guided missile camera while waving at it and what looked like the Tomahawk warhead, it had 1000LBS written on it, and a JDAM! Oh and plenty of explosives, be it manufactured or IED!
The following user(s) said Thank You: phillc54, snowgoer540
- snowgoer540
19 Jul 2021 21:51 #215343
by snowgoer540
Well you wouldn’t have to worry about free time anymore!
good news on conversational means less work lol
19 Jul 2021 22:23 #215346
LOL and sorry to disappoint you !
- fotros
22 Sep 2021 06:46 #221329
by fotros
Replied by fotros on topic QtPlasmaC release.
hi ,How can I change the gui to fit the laser cutter?
11 Apr 2022 18:17 #239951
Latest QtPlasmaC on Debian "Unstable", here is a strange one:
-home all
-wizard, 50x25mm box, inside leadin 4mm, 5mm radii on all corners
-wizard multiply at 5 columns 2 rows with 55 and 30 offsets
-send
-run
-stop using esc or cancel
-run again = it moves the start point to the second box
-stop again
-run again = it moves to start point to the third box
-rinse and repeat
-if left to continue, it will do all boxes, but they will not be where they should.
-home all
-send
-run
-stop again
-rinse and repeat
Time to create page: 0.863 seconds
