QtPlasmaC release.
  • phillc54
  • phillc54's Avatar Topic Author
  • Platinum Member
  • Platinum Member
18 Jun 2021 05:41 - 18 Jun 2021 05:42 #212310 by phillc54
Replied by phillc54 on topic QtPlasmaC release.
I'll have a bit of a look see when/if I get out to the garage later or maybe tomorrow.
It is interesting that it doesn't happen on a sim.
The machine log additions have been built, it is in the Statistics tab.
Edit: Sorry for the late reply but for some reason I am not getting any emails from the forum.
Last edit: 18 Jun 2021 05:42 by phillc54.
18 Jun 2021 09:18 #212319 by tommylight
Replied by tommylight on topic QtPlasmaC release.
All of the above is not that important, besides being so random and going away on it's own, but there is also the issue of THC doing the same thing (falling asleep) and that will cause the torch to drag on the material till the float switch is triggered, rendering the nozzle ruined.
This happens occasionaly, noticeable on longer cuts.
I would venture a guess at timers/debounce stuff, but that is only a guess.
  • phillc54
  • Platinum Member
  • Platinum Member
19 Jun 2021 03:02 #212379 by phillc54
Have you had this happen since I added some error coding on May 29?
19 Jun 2021 09:46 #212390 by tommylight
Not that i noticed, but i was just testing lately, no work since the material price is sky high here.
Will try to do more tests next week on two machines and report back.
03 Jul 2021 21:54 - 03 Jul 2021 22:13 #213599 by tommylight
Found another "falling asleep" issue, after some cuts the machine just waits and waits and ...
This is happening even when there are as little as 3 cuts in a run, be it from the wizard or Inkscape, after one or two or several cuts it just does not move to the next cut, pause and resume does not work, has to be stopped and run from line and it happily continues to run.
This is happening on 3 machines and 2 builds of the Master kind, still no updates from buildbot/stretch so i am quite some builds behind.
Edit:
Use the wizard to make a circle with outside lead in, size 50 to 75mm, feed rate at 1500mm/m, cutting 3mm mild steel at 35A, always gets a failed arc at the end, even raising arcok debounce to 50 does nothing. Resuming will just end the run, machine does nothing and that is all good. This gets very anoying when doing hundreds of cuts on a plate and having to press resume after every cut.
All of the above happens with Mode 0 , Mode 1 does this less often, but it does!
Last edit: 03 Jul 2021 22:13 by tommylight. Reason: More info
  • phillc54
  • Platinum Member
  • Platinum Member
03 Jul 2021 23:29 #213619 by phillc54
Master doesn't build on Stretch since May 11, the minimum requirement is Buster.
github.com/LinuxCNC/linuxcnc/commit/cf8e...5d3fee67c9ee29f4abbd
I will take a look at the issues.
03 Jul 2021 23:56 #213623 by tommylight
Oh well, i was not aware of that, thank you.
Back to the drawing board! :)
  • phillc54
  • Platinum Member
  • Platinum Member
04 Jul 2021 00:08 #213624 by phillc54
Yeah, it took me by surprise as well, if you check the grid you can see what builds still occur.
buildbot.linuxcnc.org/buildbot/grid
04 Jul 2021 00:30 #213627 by tommylight
I did check but apparently i was looking at the pretty colors ! :)
Updated the tutorial for Mint 19.3 to use the Buster repo, 5 additional files and we are back in business !
Now to update the rest ....
  • phillc54
  • Platinum Member
  • Platinum Member
04 Jul 2021 00:33 #213630 by phillc54
Don't forget that at the end of this month it is anticipated that master will be python3, so you will probably need to keep an eye out for that as well.
Time to create page: 0.134 seconds
