QtPlasmaC release.
5 years 6 months ago - 5 years 6 months ago #205914 by snowgoer540
Replied by snowgoer540 on topic QtPlasmaC release.
AgentWD40 wrote:
snowgoer540 wrote: What are you looking to do exactly?
I'm running a hypertherm without a RS485 port. I'd like to be able to somehow send a message to instruct the operator to manually set the amps when necessary (e.g. between center spotting and cutting operations)
AFAIK QtPlasmaC does not support that natively (but not to say it couldn't). Phill can correct me if it's secretly in there and I've missed it all this time :laugh:
Chris could also chime in if there's a native way to do this in qtVCP, but I'd guess it takes a custom M code (at least that would be one way to do it).
In the meantime two things:
1. I highly recommend RS485. I'd guess the end user only has to forget a few times and ruin a sheet of ...whatever to make the cost worth it. Once you get your tool table set up, it's literally set it and forget it. I never worry about changing the amperage, ever. I honestly don't even think about it anymore.
2. Maybe in the meantime you can get something out of this: www.forum.linuxcnc.org/38-general-linuxc...messages-my-solution Admittedly, lunch is over, so I didnt search too hard to see if there's better options.
Last edit: 5 years 6 months ago by snowgoer540.
5 years 6 months ago #205978 by phillc54
Replied by phillc54 on topic QtPlasmaC release.
I have added the use of axis B, giving a total of five available axes and LinuxCNC doesn't appear to have any keyboard keys assigned for keyboard jogging of the B axis.
I am thinking of using the "<," key for negative and the ">." key for positive. Does anyone have any complaints/suggestions???
5 years 6 months ago #205984 by tommylight
Replied by tommylight on topic QtPlasmaC release.
4'th axis uses [ and ] for keyboard jogging, never had the 5'th to try ! :(
5 years 6 months ago #205987 by phillc54
snowgoer540 wrote: Phill: Reading anything good on the Kindle??
If anyone wants a good book recommendation, highly recommend "The Martian" by Andy Weir... even if you've seen the movie (which pales by comparison) it's still worth the read.
I mostly read "junk" crime/detective books, mind numbing stuff that requires no thought processes at all.
5 years 6 months ago #205988 by phillc54
tommylight wrote: 4'th axis uses [ and ] for keyboard jogging, never had the 5'th to try ! :(
Yep, we use that for A axis, now you need to build five a axis table to find out which keys are best. :lol:
5 years 6 months ago #205995 by tommylight
Soon. ... :)
Time to create page: 0.192 seconds
