QtPlasmaC release.
5 years 6 months ago #205249 by phillc54
Replied by phillc54 on topic QtPlasmaC release.
Tom, you really are seeing some odd issues.
After probing does the z axis move up slowly to pierce height or at normal speed?
If you do a normal cut does the the z axis move up slowly at the end or normal speed?
5 years 6 months ago #205255 by tommylight
5 years 6 months ago - 5 years 6 months ago #205279 by bevins
Replied by bevins on topic QtPlasmaC release.
I am seeing something odd. Dont know if it is just me but: I updated yesterday.
When running a program, I hit cycle stop, all jogging is disabled or not working. Keyboard, gui and mpg all stops working.
Is there a delay by design? I waited 2 minutes and still no jogging. Just have to hit power button and back on then it starts jogging again.
Last edit: 5 years 6 months ago by bevins.
5 years 6 months ago #205296 by snowgoer540
Replied by snowgoer540 on topic QtPlasmaC release.
tommylight wrote: Just noticed something else :
Machine homed and ready, torch enabled, press F9 probe ok, fires the torch, jog a bit doing a short (2 -5cm) cut, press F9 again arc stops, BUT Z axis remains low, DRO shows Z axis moving very slowly up, this goes on till esc is pressed.
Never mind, more important, what can be causing the torch to move so slowly?
Checked hal and in and connections, set debounce to 1, different values for THC PID, volts per mm, no impact.
Pretty sure i messed up something as i had lately the same issue with Axis till the THC stopped working altogether, it does not enable no matter what i do to it.
In a bit i will start from scratch, see if that helps, but if it does i will have to investigate further.
Thank you all, sorry for being so absent lately.
Tommy, made a quick video here to show F9 behavior on my table. Of course the torch was off but it seems ok here. Pardon my slow probe speed, it was still set up for the height when I tested the thc on a slope cut.
The following user(s) said Thank You: bevins, tommylight
5 years 6 months ago #205314 by bevins
Thanks, that update fixed the jogging issue.
5 years 6 months ago #205316 by tommylight
Replied by tommylight on topic QtPlasmaC release.
Sorry for the slow response,
After the latest update i could not reproduce the slow retraction from F9 use, so all good as far.
But still did not figure out the slow reaction of the THC, will try to do a new config later on.
Snowwy, thank you.
Time to create page: 0.123 seconds
