QtPlasmaC release.
- Franklin
- Thank you received: 19
28 Mar 2021 11:31 #203887
by Franklin
Replied by Franklin on topic QtPlasmaC release.
understood thanks
- Thank you received: 7470
28 Mar 2021 14:47 #203907
Replied by tommylight on topic QtPlasmaC release.
No "run from here" ?
- snowgoer540
- Thank you received: 906
28 Mar 2021 15:06 - 28 Mar 2021 15:06 #203909
by snowgoer540
You need to enable it on the Parameters Tab:
linuxcnc.org/docs/devel/html/plasma/qtpl...tml#qt_run-from-line
Replied by snowgoer540 on topic QtPlasmaC release.
Last edit: 28 Mar 2021 15:06 by snowgoer540.
28 Mar 2021 16:09 #203911
- phillc54
- Thank you received: 2100
29 Mar 2021 01:32 #203970
by phillc54
I have pushed the fix for this. I should have used W.kerf_width.value() This also affected a few other shapes.
Replied by phillc54 on topic QtPlasmaC release.
Hi I am trying to use QtPlasmaC and in the conversational tab I keep getting the error message. I tried on two computers and get the same errors.
File "/usr/lib/python2.7/dist-packages/qtvcp/lib/qtplasmac/conv_rectangle.py", line 110, in preview kOffset = float(W.kerf_width.text()) * W.kOffset.isChecked() / 2 ValueError: invalid literal for float(): 1,00
The following user(s) said Thank You: Franklin
- Franklin
30 Mar 2021 15:30 #204134
by Franklin
Thanks Phill, it already works great. I would like to know, are you planning to add a virtual keyboard in the "conversational" tab? For use touch display alone without a keyboard and mouse.
- phillc54
30 Mar 2021 22:19 #204155
by phillc54
I will probably look at that in the future, I have only recently got a touchscreen for testing. Aat the moment I just use Onboard keyboard.Thanks Phill, it already works great. I would like to know, are you planning to add a virtual keyboard in the "conversational" tab? For use touch display alone without a keyboard and mouse.
01 Apr 2021 18:15 #204413
Sorry for rushing in, but earlier on i found 2 new topics about THC not moving/reacting/following material (was on another PC), and i did notice that after installing QtPlasmaC on the big machine yesterday, checked a bit today and sure enough it does react/move/follow, but at an abysmally slow rate even with PID settings set at maximum values.
Is there something i am missing ?
And LinuxCNC complains about old style debounce...
Later,
sorry
Later,
sorry
01 Apr 2021 20:26 #204425
More info, this is with 2.9/Master updated today, same with build from two days ago.
- phillc54
01 Apr 2021 22:45 - 02 Apr 2021 00:39 #204447
by phillc54
EDIT: fix has been pushed
I see that too Tom, oops, I think I broke it. I'll take a look today.Sorry for rushing in, but earlier on i found 2 new topics about THC not moving/reacting/following material (was on another PC), and i did notice that after installing QtPlasmaC on the big machine yesterday, checked a bit today and sure enough it does react/move/follow, but at an abysmally slow rate even with PID settings set at maximum values.
I have been meaning to get rid of that as well, I need to look around to see if I can find some more time...And LinuxCNC complains about old style debounce...
Last edit: 02 Apr 2021 00:39 by phillc54.
Time to create page: 0.574 seconds
