Just noticed something else :
Machine homed and ready, torch enabled, press F9 probe ok, fires the torch, jog a bit doing a short (2 -5cm) cut, press F9 again arc stops, BUT Z axis remains low, DRO shows Z axis moving very slowly up, this goes on till esc is pressed.
Never mind, more important, what can be causing the torch to move so slowly?
Checked hal and in and connections, set debounce to 1, different values for THC PID, volts per mm, no impact.
Pretty sure i messed up something as i had lately the same issue with Axis till the THC stopped working altogether, it does not enable no matter what i do to it.
In a bit i will start from scratch, see if that helps, but if it does i will have to investigate further.
Thank you all, sorry for being so absent lately.
