QtPlasmaC release.
5 years 6 months ago - 5 years 6 months ago #205626 by bevins
Replied by bevins on topic QtPlasmaC release.
phillc54 wrote:
bevins wrote: I tried loading the new QTplasmaC, with new pncconf.
It made no connections for the probe, thc etc.... So I am at a loss on how to make these connections. I followed the instructions with the docs. did the conversion and the cfgprefs...... from existing working plasmac
Here is what I came out with as config but no thc and no probe.
Did you select a plasmaa float switch or plasma ohmic probe in pncconf?
Did you select a plasma arc voltage encoder in pncconf?
I selected plasma float and probe and it did add everrything except thc stuff.
I set the thcad freqs and stuff but did not find where to set for arc voltage - encoder.00.velocity
Nevermind, I found it in pncconf. Thanks
Last edit: 5 years 6 months ago by bevins.
5 years 6 months ago #205850 by phillc54
Replied by phillc54 on topic QtPlasmaC release.
A few folk have asked if it was possible to move the DRO to the top of the GUI.
There is now an option that can be set in the .ini file to do this for both the 16:9 and 4:4 display formats.
In the [QTPLASMAC] section of the .ini file add the following:
DRO_POSITION = top
5 years 6 months ago #205867 by Clive S
Replied by Clive S on topic QtPlasmaC release.
With me getting old and a bit forgetful may a I ask a newbie question?
I run mint 19.2 with 2.8.1 on several machines but I am missing out on QTplasmaC. I realise I need 2.9 master
Q.1 So do I have to install Buster (that I don't like) or can I still use mint updated to 2.9 ?
Q.2 Is there a different GUI colour other than yellow ?
Sorry if this post is in the wrong place if so can you move it elsewhere. (not to the bin I hope) :)
5 years 6 months ago #205870 by phillc54
Clive S wrote: With me getting old and a bit forgetful may a I ask a newbie question?
AFAIK it should work on Mint.
Colours are user changeable, see the GUI SETTINGS chapter here:
linuxcnc.org/docs/devel/html/plasma/qtpl...ml#qt_parameters-tab
Haha, I wouldn't do that to you Clive.
5 years 6 months ago #205873 by tommylight
Replied by tommylight on topic QtPlasmaC release.
Yes you can use mint 19.x.
Clive S wrote: Q.2 Is there a different GUI colour other than yellow ?
Yes they can be changed to whatever, but i have yet to find something that looks better than default. :(
5 years 6 months ago #205874 by tommylight
Phill, sorry to bother, but:
Press F9, jog manually right, press F9 while still holding the jog button, release the jog button = machine continues to move right till it hits the limits ... or gets out of the shop ! :)
Pressing the arrow key stops it.
Latest master, as usual.
Off to the shop, soon .... :)
Time to create page: 0.134 seconds
