Help with QTplasmaC
- Thank you received: 7485
17 Apr 2021 22:05 #206233
If the X axis is not tandem it can be jogged without homing it first, so that tells me there is more missing than a joint/axis.
Replied by tommylight on topic Help with QTplasmaC
If i recall correctly, QtPlasmaC shows only 3 axis all the time although i have 4 joints, not very clear on this as i was chasing the slow THC thingy ........... but PlasmaC shows 4 axis until homed but QtplasmaC is only showing 3 I cannot jog any motors or home the machine yet.
- phillc54
- Thank you received: 2100
17 Apr 2021 23:30 #206240
by phillc54
Replied by phillc54 on topic Help with QTplasmaC
QtPlasmaC only show the axes, not the joints regardles of the " kinstype=both" setting in the ini file.
This is a no win situation where it confuses some folk to have 4 "axes" dispalyed when they only have three and confuses other folk who expect to see 4 "joints".
- txtrone
- Thank you received: 106
18 Apr 2021 00:31 #206246
by txtrone
This image shows Z Axis stepgen inverted, or am I losing my mind?
I am having the same issue with not being able to home the X axis (the tandem in my case).
Replied by txtrone on topic Help with QTplasmaC
It might be better to start pncconf, and edit it that way.
You just click on the drop down, click Axis > Tandem Axis > pick whatever suits your tandem axis, usually it's Y, so Y2 Tandem StepGen.
That's it really.
The only thing that is confusing is you may have to invert the direction for one of the Y motors. It will be listed under that Joint, but it's confusing because it's next to "Unused StepGen" then Dir Gen-B, and you can click Inv there.
I show it clicked in this view, just so you can see it, you'll have to figure out if you need it or not.
Attachment not found
- phillc54
18 Apr 2021 00:39 #206247
by phillc54
Yep, you are correct. This catches me out a lot as well, the DIR pin is above the STEP pin.
The following user(s) said Thank You: txtrone
- txtrone
18 Apr 2021 01:02 #206249
by txtrone
No dice getting Qtplasmac to home my tandem X axis. I will try installing Plasmac Monday and see if I can get that to work. I jumped the gun trying to install a beta on my first go round!
- phillc54
18 Apr 2021 01:07 #206250
by phillc54
What is it doing/not doing?
Homing is done by LinuxCNC, QtPlasmaC should have no effect.No dice getting Qtplasmac to home my tandem X axis. I will try installing Plasmac Monday and see if I can get that to work. I jumped the gun trying to install a beta on my first go round!
- txtrone
18 Apr 2021 01:25 #206253
by txtrone
When I load up QtPlasmac I 'power' up the machine and clear estop... then click on the 'home' buttons for x y and z. The y axis and z axis 'buttons' light up.... the x does not. When I jog the machine I have one X (the tandem) that will not move. I think I am having the same issue Clive is/was having.
- phillc54
18 Apr 2021 01:37 #206254
by phillc54
Can you post a compressed file of your config.
- txtrone
18 Apr 2021 01:39 #206255
by txtrone
I already used timeshift to restore my pc to where it was before I installed 2.9 or qt. I will probably install plasmac next week, at least get that going... then when qt and 2.9 are officially out I will try again.
- phillc54
18 Apr 2021 01:50 - 18 Apr 2021 04:43 #206256
by phillc54
but no corresponding switch for the tandem Y axis.
You have the X axis "HOME_FINAL_VEL" commented out.
This line:needs changing to:
Can you try individually homing the Z axis then the X axis. Do any of them home?
I also would have expected something like:in the "# Step Gen signals/setup" part of "# AXIS Y JOINT 3 Tandem" in the HAL file so that this motor runs in reverse to the main motor. Although you may already have the motor reversed in the wiring...
Edit:
I believe you use a THCAD for Arc Voltage. If so you haven't selected a Plasma Encoder in PncConf.
Can you confirm that the 7i96 Step0 is the X axis, 7i96 Step1 is the Z axis, 7i96 Step2 is the Y1axis, and 7i96 Step3 is the Y2 axis.
TBH I am not sure if the joint assignment is causing any issues, I see that when I run you parameters through PncConf if sets [TRAJ]COORDINATES as XYYZ, [KINS]KINEMATICS to trivkins coordinates=XYYZ and assigns AXIS_X to JOINT_0, AXIS_Y to JOINT_1 and JOINT_2, and AXIS_Z to JOINT_3 then just send the output to the correct stepgen in the HAL file.
That works fine in a sim so should not be a problem. There was an issue with the jog keys/buttons and I have pushed a fix for that.
Edit2: Attached is a pncconf file I ran with your parameters, you could try running PncConf with it and change anything that doesn't look right. You will need to enter the correct THCAD parameters and I just guessed the pin# for the tandem Y min-limit/home switch.
Don't forget to backup the existing config or rename the machine name.
Clive, a couple of things I see is you have:I cannot jog any motors or home the machine yet. But do see the in halshow the various sensor working ok.
I am not sure what I am missing from the hal file. The motors are enable as they are locked
I will have to have another go in the morning.
net min-home-y <= hm2_7i96.0.gpio.005.inYou have the X axis "HOME_FINAL_VEL" commented out.
This line:
net plasmac:axis-position joint.2.pos-fb => plasmac.axis-z-positionnet plasmac:axis-position joint.1.pos-fb => plasmac.axis-z-positionCan you try individually homing the Z axis then the X axis. Do any of them home?
setp hm2_7i96.0.stepgen.03.direction.invert_output trueEdit:
Last edit: 18 Apr 2021 04:43 by phillc54.
Time to create page: 0.170 seconds
