Torch On HAL Pin when using 7i76e
- snowgoer540
- Thank you received: 907
21 Apr 2021 11:24 #206672
by snowgoer540
As I said, you need to use the ohmic.comp (included with LinuxCNC). Or ohmic2.comp, or ohmic3.comp (in the link below, as well as how to install them).
Rod has posted examples of how to hook up the hal stuff. Including his own .hal files.
Here's at least one thread to read: forum.linuxcnc.org/plasmac/38848-hypersensing-questions?start=0
It details my (and a few others by the end) journey into "hypersensing", and as such has a lot of answers to questions with regard to getting it working, how it's evolved, and why it is the way it is.
It's 28 pages long, but it's worth the read.
In a nutshell, you need to pass the ohmic probe output from PlasmaC to the ohmic component. In addition, you need to pass the encoder velocity to the ohmic component. The output of the ohmic component will be passed to the PlasmaC ohmic input.
Replied by snowgoer540 on topic Torch On HAL Pin when using 7i76e
True, but it looks like he's attempting "hypersensing", so he will need one of the ohmic components. There's a few threads around here that explain it better than I can off the top of my head.
- txtrone
- Thank you received: 106
21 Apr 2021 12:36 #206686
by txtrone
That solved the communication problem with my HyperTherm!
Now I am sifting through 28 pages of hypersensing evolution...
Replied by txtrone on topic Torch On HAL Pin when using 7i76e
Type is the type of pin, be it bit, float, s32 etc.
Dir should be the direction of the signal looking from the LinuxCNC point of view. Might wana check this as i am a bit cloudy...
As for coms, might need to add the user to dialout, here is one of the many topics about that:
arduino.stackexchange.com/questions/7471...d-to-group-dialout-o
- txtrone
21 Apr 2021 13:30 #206693
by txtrone
Just sorted through the 28 pages. I am a bit confused on ohmic comp versions and if I have one installed already or not. How can I check to see if ohmic comp is installed already?
Also, what is the verdict on using a relay to interrupt the power supply?
- txtrone
21 Apr 2021 13:34 #206695
by txtrone
Is the relay that sends power to THCAD optional?
This went sideways rather quickly...
The "Ohmic Probe Enable" pin in the configurator must be a physical output that is wired to the relay that activates the power going to the sensing part of THCAD.
Any normal output can be used for that.
- snowgoer540
21 Apr 2021 13:35 #206696
by snowgoer540
You have ohmic.comp installed by default. you would have to install ohmic3 (I wouldnt see much point in using ohmic2)
User's choice.
User's choice.
The following user(s) said Thank You: txtrone
- txtrone
21 Apr 2021 13:39 #206697
by txtrone
Ok, but 'regular' ohmic is ok to use? Or I need to install ohmic3?
You have ohmic.comp installed by default. you would have to install ohmic3 (I wouldnt see much point in using ohmic2)User's choice.
- txtrone
21 Apr 2021 15:45 #206702
by txtrone
Wait a minute, what if I am not using the "Optional" relay?? Would I comment out the ohmic enable HAL pin?
I suspect it's going to take issue with your ohmic enable HAL pin next as you are feeding a bit output to an encoder.
- Thank you received: 7502
21 Apr 2021 16:28 #206712
But i think someone here made due without it.
Replied by tommylight on topic Torch On HAL Pin when using 7i76e
Correct, but not advisable since the pilot arc generates anything in the 2000V to 15000V and that should give it some distance in case something goes south.Wait a minute, what if I am not using the "Optional" relay?? Would I comment out the ohmic enable HAL pin?
- txtrone
21 Apr 2021 17:22 #206723
by txtrone
Thanks Tommy. That makes more sense, I was going crazy trying to assign an output to something that did not exist!
Since I need to add a relay to my 'sense' circuit anyways... would you advise a newbie like me to use 'hypersensing' or 'regular sensing'? If I need to add the optional relay anyways, it would be trivial to remove the extra THCAD and wire up the multi-relay 'traditional' sense setup.
I am sure hypersense is far superior, but I just want to get up a running. At this point (with ohmic enable temporarily commented out) Plasmac loads, jogs correctly, proximity sensors are indicating correctly, and my HyperTherm is communicating.
Correct, but not advisable since the pilot arc generates anything in the 2000V to 15000V and that should give it some distance in case something goes south. But i think someone here made due without it.
- snowgoer540
21 Apr 2021 17:24 #206724
by snowgoer540
I am not quite sure about ohmic, but ohmic3 uses the hal enable pin as a check for whether or not the output is true.
In other words, if the voltage > threshold, and NO ohmic enable input, there is no output from the component.
So you need to provide the enable whether or not you plan to use a relay. I thought this was documented in the hypertherm thread. Maybe it was somewhere else. Either way Rod's guided several people on here through the use of his ohmic3 component. I would seek out one of those threads if it's not in the hypersensing thread I linked earlier.
Time to create page: 0.784 seconds
