Torch On HAL Pin when using 7i76e
- txtrone
- Thank you received: 106
21 Apr 2021 22:29 #206725
by txtrone
Ok, also... do I need some sort of custom firmware from Mesa to make hypersense work with the 7i76e? Seems like I have read that somewhere... maybe in the 28 pages of posts, or the manual, or the primer, or maybe I am thinking about the ohmic/2/3...
Replied by txtrone on topic Torch On HAL Pin when using 7i76e
I am not quite sure about ohmic, but ohmic3 uses the hal enable pin as a check for whether or not the output is true.
In other words, if the voltage > threshold, and NO ohmic enable input, there is no output from the component.
So you need to provide the enable whether or not you plan to use a relay. I thought this was documented in the hypertherm thread. Maybe it was somewhere else. Either way Rod's guided several people on here through the use of his ohmic3 component. I would seek out one of those threads if it's not in the hypersensing thread I linked earlier.
- snowgoer540
- Thank you received: 907
21 Apr 2021 22:47 #206730
by snowgoer540
If you also have a THCAD for THC, then yes.
Replied by snowgoer540 on topic Torch On HAL Pin when using 7i76e
- txtrone
21 Apr 2021 23:05 #206734
by txtrone
Where can I find the instructions on the mesa driver installation that I would need?
- Thank you received: 4150
21 Apr 2021 23:18 - 21 Apr 2021 23:21 #206737
Replied by rodw on topic Torch On HAL Pin when using 7i76e
Ok, because you are using a downdraft table and don't have to contend with water splashing around, the best course of action is to use the original ohmic.comp that is part of the Linuxcnc deployment from 2.8 and up.
You have no need for all the fancy crap Ohmic3 does to try and work around the water table problems where the voltage drop can be less than 1 volt between the probe on and off.
The correct pin name for ohmic sense probing is
The documentation is here linuxcnc.org/docs/devel/html/man/man9/ohmic.9.html
or available if you type
The suggested connections in your machine.hal file are shown in the documents. Note that on a new installation, the last line
These pins control the voltage threshold:In this example, the probe comes on when the voltage is > 22 volts and goes off when its < 1 volt.
I would jog the torch down so it touches the material and use halshow to review the voltage on this pinbefore setting the upper threshold. On my system I always get 24 volts so a threshold of 22 works for me but you may wish to set it lower (18v maybe?)
And yes the relay to turn the AC side off is optional. I think I have bypassed the relay.
The only reason to turn the power off is becasue there have been some suggestions of the possibility of electrolytic corrosion inside the torch tip on water tables (water shorting out the internal contacts) when machines that are left powered on while idle for long periods. But because you have a dry table, this will not be an issue for you.
So in your case, keep it simple, leave the relay out and just turn the power supply on when you power up the machine!
ohmicsense.ohmic-onThe documentation is here linuxcnc.org/docs/devel/html/man/man9/ohmic.9.html
man ohmicThe suggested connections in your machine.hal file are shown in the documents. Note that on a new installation, the last line
will be added from pncconf or the Plasmac configurator so it should be omittednet ohmic-true ohmicsense.ohmic-on => plasmac.ohmic-probe
setp ohmicsense.threshold 22
setp ohmicsense.ohmic-low 1I would jog the torch down so it touches the material and use halshow to review the voltage on this pin
ohmicsense.ohmic-voltsAnd yes the relay to turn the AC side off is optional. I think I have bypassed the relay.
Last edit: 21 Apr 2021 23:21 by rodw.
The following user(s) said Thank You: txtrone
21 Apr 2021 23:25 #206738
On the mesa product page, there is a zip file that includes lots of bit files for different configs. the one to use ends with pl.bit (where pl = plasma)
You need to use mesaflash to burn this to the 7i76e
I do show how to do this in my video
- txtrone
21 Apr 2021 23:28 #206739
by txtrone
Thanks Rod! Shall I leave the ohmic enable line commented out in my hal file for now, or is that what you are saying I need to delete? Sorry, not in front of the machine right now. Also, what about the mesa firmware, do I need to load another version on the 7i76e?
The correct pin name for ohmic sense probing isohmicsense.ohmic-on
or available if you typeman ohmic
The suggested connections in your machine.hal file are shown in the documents. Note that on a new installation, the last linewill be added from pncconf or the Plasmac configurator so it should be omittednet ohmic-true ohmicsense.ohmic-on => plasmac.ohmic-probe
These pins control the voltage threshold:In this example, the probe comes on when the voltage is > 22 volts and goes off when its < 1 volt.setp ohmicsense.threshold 22 setp ohmicsense.ohmic-low 1
I would jog the torch down so it touches the material and use halshow to review the voltage on this pinbefore setting the upper threshold. On my system I always get 24 volts so a threshold of 22 works for me but you may wish to set it lower (18v maybe?)ohmicsense.ohmic-volts
- txtrone
21 Apr 2021 23:32 #206740
by txtrone
Thanks again Rod! I will let you know how it goes tomorrow.
- txtrone
22 Apr 2021 15:14 #206803
by txtrone
This is the error I am getting:
twopass: Error in file ./mark_i_connections.hal:
setting parameter 'hm2_7i76e.0.encoder.02.scale' to '-1'
parameter or pin 'hm2_7i76e.0.encoder.02.scale' not found
