- Thank you received: 22
Thc velocity low
- paulsao
5 years 1 month ago #221318
by paulsao
Replied by paulsao on topic Thc velocity low
- snowgoer540
- Thank you received: 907
5 years 1 month ago #221332
by snowgoer540
Replied by snowgoer540 on topic Thc velocity low
That would seem to be a problem then.
These two values in the config tab are what control that:
It would seem that you have not calculated them correctly, as a 7.6v battery should show 7.6v on the GUI.
You might try this calculator to help you: jscalc.io/calc/NTr5QDX6WgMThBVb
Otherwise we'd need more info about your setup.
arc-voltage-offset=3728.125
arc-voltage-scale=0.008314
The following user(s) said Thank You: paulsao
- Thank you received: 7491
5 years 1 month ago #221337
Replied by tommylight on topic Thc velocity low
Another stab in the dark, but can you check what is the value of
plasmac.thc-feed-rate
pin?
pin?
- paulsao
5 years 1 month ago #221343
by paulsao
- snowgoer540
5 years 1 month ago - 5 years 1 month ago #221344
by snowgoer540
Pretty sure you need to leave any scaling resistors in place when doing this test, and they need to be accounted for in the calculations for the calculations to be correct.
But I dont use a scaling resistor, and I've not done the math, so someone else will have to chime in and confirm.
Last edit: 5 years 1 month ago by snowgoer540.
5 years 1 month ago #221345
All looks good, thank you.
Not related to this but you might want to change the VAD threshold to 60-70%.
Time to create page: 4.958 seconds
