- Thank you received: 22
Thc velocity low
- paulsao
5 years 1 month ago #221288
by paulsao
Replied by paulsao on topic Thc velocity low
ok thanks for your help, if really if the z axis moves how it should move but they are I am sure that if it should move 1mm it will move that distance, now you can help me where I look for information to update plasmac to the latest version and then of that I will prove the pid with 20 as you say.
- snowgoer540
- Thank you received: 907
5 years 1 month ago #221299
by snowgoer540
Replied by snowgoer540 on topic Thc velocity low
The following user(s) said Thank You: paulsao
- paulsao
5 years 1 month ago #221304
by paulsao
I upgraded to the latest version of Plasmac, I did tests at 300mm / min and the thc works fine, I raised the cutting speed to 1000mm / min and it no longer works very well on an inclined steel plate touch the torch and the reading of the the voltage seems to vary rapidly.
- snowgoer540
5 years 1 month ago #221308
by snowgoer540
Kind of poking in the dark here, but here are some things that cant hurt to look at:
Have you confirmed the voltage readings with a known, isolated source, such as a 9v battery?
Have you verified that the axes move the commanded amount? For example if you tell Z to move 25mm have you verified it actually moves 25mm? (same with X and Y)
How angled is the piece of material you are trying to cut? Sometimes if the angle is too steep, the shield can touch the material inadvertently.
- paulsao
5 years 1 month ago #221316
by paulsao
- snowgoer540
5 years 1 month ago #221317
by snowgoer540
Check the battery with a multimeter and then verify the arc voltage displayed in plasmac matchesÂ
Time to create page: 0.287 seconds
