- Thank you received: 22
Thc velocity low
- paulsao
5 years 1 month ago #221349
by paulsao
Replied by paulsao on topic Thc velocity low
- Thank you received: 5334
5 years 1 month ago - 5 years 1 month ago #221353
Replied by PCW on topic Thc velocity low
What are your Z axis MAX_ACCELERATION and MAX_VELOCITY values?
Last edit: 5 years 1 month ago by PCW.
The following user(s) said Thank You: paulsao
- paulsao
5 years 1 month ago #221354
by paulsao
- snowgoer540
- Thank you received: 907
5 years 1 month ago #221360
by snowgoer540
Replied by snowgoer540 on topic Thc velocity low
If you are sure the voltages are correct, you could try increasing the P value in the THC settings area of the config tab from 10 to 20.
5 years 1 month ago - 5 years 1 month ago #221364
The acceleration (750 mm/s^2) and 1200 mm/m velocity
should allow ~0.5 mm minimum radius so that is not likely
the limiting factor.
(750 rather than 1500 mm/s^2 because only 1/2 the full acceleration is available to the THC)
- paulsao
5 years 1 month ago #221369
by paulsao
Thanks for you explicatiion, Can the PID values that I have in the joints affect something? In P I have 1000.
Time to create page: 4.426 seconds
