- Thank you received: 5334
Thc velocity low
5 years 1 month ago #221379
Replied by PCW on topic Thc velocity low
No, the stepgen PID values are correct.
The physical meaning of a P term of 1000
at a 1 ms servo thread rate is that any
stepgen accumulated position errors
are corrected at the next waypoint
(1 ms later)
(1 ms later)
The following user(s) said Thank You: snowgoer540, paulsao
- paulsao
- Thank you received: 22
5 years 1 month ago - 5 years 1 month ago #221384
by paulsao
Replied by paulsao on topic Thc velocity low
Last edit: 5 years 1 month ago by paulsao.
- phillc54
- Thank you received: 2100
5 years 1 month ago #221385
by phillc54
Replied by phillc54 on topic Thc velocity low
The only thing I see is that plasmac.thc-feed-rate is 6000mm/min but the MAX_VEL in the joint is only 3000mm/min (50 x 60)
AXIS_Z MAX_VEL should be 100 (JOINT_# MAX_VEL * 2)
I don't know if that would cause an issue or not...
The following user(s) said Thank You: paulsao
5 years 1 month ago #221392
If the Z velocity and voltage were plotted in halscope,
that might give a clue to where the bottle-neck is.
- paulsao
5 years 1 month ago #221447
by paulsao
Well guys after a night without sleep you see that the activation time of the thc was at 1.5s and it was too much for the slope of the metal that I wanted to cut and it did not allow to activate the thc I reduced it to 0.5 and it worked up to 2000 mm / min, thanks for his time I am still learning and calibrating my machine and reading a lot.
The following user(s) said Thank You: phillc54, tommylight, snowgoer540
- Thank you received: 7491
5 years 1 month ago #221451
Replied by tommylight on topic Thc velocity low
Yeah i forgot that PlasmaC had 1.5 seconds of delay on the THC, i wonder who's idea was that?
Glad you figured it out.
Time to create page: 4.844 seconds
