Framing set origen
- paulsao
- Thank you received: 22
03 Nov 2021 19:58 #225140
by paulsao
Replied by paulsao on topic Framing set origen
Framing turns the laser on, but it is not on the path that corresponds to the actual cut.
- snowgoer540
- Thank you received: 905
03 Nov 2021 20:11 #225144
by snowgoer540
Replied by snowgoer540 on topic Framing set origen
I messed with this a bit after work (using a pencil as my laser haha). I think I do see the issue. I will try to see if I can fix it.
The following user(s) said Thank You: paulsao
- paulsao
03 Nov 2021 20:20 #225149
by paulsao
Thanks lol I think the framing should not use the offsets (x and y) it just follows the framing of the current G code.
- snowgoer540
03 Nov 2021 20:29 #225151
by snowgoer540
the intent is when you have a laser, it will frame with the laser.
it's a sign issue in the code. It will be fixed soon
- paulsao
03 Nov 2021 21:01 #225153
by paulsao
Ok Thanks luckily you could understand me
- snowgoer540
03 Nov 2021 21:40 #225157
by snowgoer540
Should be fixed, I pushed a commit for Phill to approve. If approved you'll just have to wait for the buildbot to do its thing, and update later.
Before:
After:
Before:
Warning: Spoiler!
After:
Warning: Spoiler!
- paulsao
03 Nov 2021 21:44 #225158
by paulsao
thanks that looks good.
- Thank you received: 4148
04 Nov 2021 01:18 #225183
Replied by rodw on topic Framing set origen
To me that does not look right. Setting up Framing is next on my plasma agenda.
Say you have a job that starts at the origin 0,0 and your laser offsets are 50mm, 50mm (or 2 x 2 dinosaurs)
You move the laser to the 0,0 position you want to use and touch off with the laser. The offsets are changed but plasmac does not move the torch to the 0,0 position (which is how I did it in Gmoccappy) So if the framing is now based on the torch position, you would have to issue a G0 X0 Y0 before framing for it to track the job.
I think the laser touchoff should move the torch to the new 0,0 position for this method to be accurate.
Wait until I test before panicking.
- Thank you received: 7468
04 Nov 2021 01:50 #225185
Was thinking the same thing since this topic started, but since i do not use the feature, i kept my mouth shut!
Replied by tommylight on topic Framing set origen
- paulsao
04 Nov 2021 01:59 #225186
by paulsao
Rodw did all that but it did not work after placing my origin I smashed the x0y0 button but it does not solve the problem, now I tried the recent update and it is working as it should.
Time to create page: 0.361 seconds
