Framing set origen
- Thank you received: 4148
05 Nov 2021 00:05 #225309
I had dunked the torch while testing and the first pulse was all water and no sparks so it has a purpose!
Yeh, Thats what I had in mind. Would be a way cool feature!
Replied by rodw on topic Framing set origen
Silly me of course you need to enable the torch!You need to be out of estop, power on and torch enabled. It does work here on my table at this very moment.
[/quote]We could probably look at this as a user button function.
- paulsao
- Thank you received: 22
05 Nov 2021 00:07 #225310
by paulsao
Replied by paulsao on topic Framing set origen
For activate pulse button first activate torch on.
05 Nov 2021 00:24 #225312
Just thinking out loud.
Add to the load last button Load next button with an archive option
I'll have to think about it a bit more but say the machine has an operator on it and design sends a heap of jobs to it during the last shift.
I'm thinking of some way to allow the operator to work through the list
Actually scratch all that and just add a run python option and let the user set it up how he likes.
That would be cool.....
05 Nov 2021 00:27 #225314
So let a run-python button receive a parameter for the current file name and a method to load a new file into QTP
You'll be pleased to know I'm running out of ideas......
- phillc54
- Thank you received: 2100
05 Nov 2021 00:39 #225316
by phillc54
Replied by phillc54 on topic Framing set origen
Do you mean the operator needs to enter the file name?So let a run-python button receive a parameter for the current file name and a method to load a new file into QTP
- paulsao
05 Nov 2021 01:51 - 05 Nov 2021 01:53 #225325
by paulsao
Today I had to do a quick job and use the simple cut function and I wanted to use the laser to see where the sheet was cut and if it was straight but it seems to have the same problem that offsets, so I had to guide me by the torch
Last edit: 05 Nov 2021 01:53 by paulsao.
- snowgoer540
- Thank you received: 905
05 Nov 2021 02:06 #225327
by snowgoer540
Replied by snowgoer540 on topic Framing set origen
Can you post the gcode you’re having difficulty with ?
- paulsao
05 Nov 2021 02:10 #225328
by paulsao
It is only when I use the simple cut button function, it is just a straight that cuts the shaft. Simple cut at x = 50 is just a cut line.
- snowgoer540
05 Nov 2021 02:13 #225329
by snowgoer540
Was it off in X or Y?
I am sure I checked single cut with an offset applied for X in an X direction cut. I’m not sure if I checked with an offset applied for X and Y with just an X cut.
I’ll have to have a closer look tomorrow.
The following user(s) said Thank You: paulsao
- paulsao
05 Nov 2021 02:15 #225331
by paulsao
X=50
Y=0
Only x
Y=0
Only x
Time to create page: 0.386 seconds
