Framing set origen
- snowgoer540
- Thank you received: 905
05 Nov 2021 02:18 #225332
by snowgoer540
Replied by snowgoer540 on topic Framing set origen
I meant what direction was the laser off in?
- paulsao
- Thank you received: 22
05 Nov 2021 02:25 #225333
by paulsao
Replied by paulsao on topic Framing set origen
I'll check it out tomorrow, I'm done with my work shift.
- snowgoer540
05 Nov 2021 02:27 #225334
by snowgoer540
No need, I see the issue. I’ll work out a solution then.
- paulsao
05 Nov 2021 02:31 #225335
by paulsao
- snowgoer540
05 Nov 2021 03:04 #225339
by snowgoer540
I take back what I said. This seems right to me in a simulation (at 11:03pm anyways). I will have to check it on the machine tomorrow.
- Thank you received: 4148
05 Nov 2021 07:43 #225368
It worked for me today? I entered x = 1200, y = 0 and it worked nice. Cut from torch position to 1200
My understanding is the move is relative to the torch position but I usually only use it to sever a 1200 wide sheet, starting at x = 0
Replied by rodw on topic Framing set origen
Was that using the button function?Today I had to do a quick job and use the simple cut function and I wanted to use the laser to see where the sheet was cut and if it was straight but it seems to have the same problem that offsets, so I had to guide me by the torch
05 Nov 2021 07:44 #225369
I don't think the laser is designed to follow such a cut. Its just for alignment, zeroing and rotation.
- phillc54
- Thank you received: 2100
05 Nov 2021 07:59 #225370
by phillc54
Replied by phillc54 on topic Framing set origen
If it worked with the latest version then your offsets are in the wrong direction.
THe offsets are measured from the torch position, similar to the tool offsets for the scribe.
The code needs to be reverted to what it was for consistency. I will do this tomorrow.
I also added the ability to load the latest file from a directory today.
05 Nov 2021 08:01 #225372
1. allowed a python script to be run and that the script was passed the current file name
2. Had a method to load an arbitrary file name into qtplasmac.. I thought this might be automated using a folder watcher or something.
One application might be for the user to hit a load next button and the current file was archived (moved to a done folder) and the user supplied script would load the next file to be processed if another one existed in the input folder.
No I was thinking if the button code:
So let a run-python button receive a parameter for the current file name and a method to load a new file into QTP
Do you mean the operator needs to enter the file name?
- phillc54
05 Nov 2021 08:06 #225375
by phillc54
I don't have any interest in getting into file handling.
Time to create page: 0.137 seconds
