Sheetcam revised post - please test
- phillc54
- Thank you received: 2100
- Thank you received: 4151
Thanks Phillc54.
So only workaround is to go to an old pp and choose the material in QTPlasmac?
James can you try editing the post and set
useTool = falseYour Sheetcam tool number must matche your QTPlasmac tool number.
Hopefully that will retrieve the tool from QTPlasmac. there is a plasmac script to import tools.
Phil, it would be good if you could rework the code to support this. There is only going to be more users using sheetcam's included post. They should not be disadvantaged. I guess we could also add the tool number to the magic comment, then you would have it.With the current G-Code filter you won't be able to run from line if you use temporary materials. We could probably rework the filter so that this is possible.
- phillc54
- snowgoer540
- Thank you received: 907
Otherwise, I'd have to remember to go back to SheetCAM and make the same changes. But I'm willing to entertain that I'm missing something.
- phillc54
I use the QtplasmaC material file as the master as well, with no material selection at all from SheetCam, that way I can cut the same job with different materials by manually selecting the material for the job.
- snowgoer540
The original idea behind it was that it may be handy for a oneoff test of a cut.
I suppose I could see that being useful, before one commits a material number to the library.
I had not considered that as an option. I think I would forget to set the material too often (like with some of my recent kerf-cross tests
It is nice to learn a new option though. Interesting to learn everyone's preferred work flows.
- phillc54
Why edit code when you could be lazy like me and just go click click.I had not considered that as an option. I think I would forget to set the material too often (like with some of my recent kerf-cross tests
). Normally I edit the code and change the material number.
- snowgoer540
Let's just say material 0's settings consistently leave something to be desired
I was using it well before I used Plasmac.
An existing Sheetcam user migrating to QTPlasmac will have all of his cutcharts sorted so probably does not need to import his settings into Plasmac. That just adds another layer of complexity.
The real issue I guess is that we have data redundancy because we have two sources of the same info so there is not a single point of truth. Its really up to the user to choose and maintain his single point of truth.
Plasmac's moved on a lot but I chose Sheetcam to be my SPOT. It was much easier to maintain cut charts in Sheetcam. I will say it is convenient to update data in plasmac but then if I grab the Thermal Dynamics manual to check settings it will be when using Sheetcam when setting up a job.
I did try to update Sheetcam after any change. eg. I might be cutting a new (to me) material, I might end up with a voltage or cut override which I then convert in my head to specific number to update the chart with.
Anyway, to Phil's credit he did a good job of incorporating the requirements for a post processor to control job settings.
