Sheetcam revised post - please test
- phillc54
- Thank you received: 2100
13 Nov 2021 07:01 #226286
by phillc54
Replied by phillc54 on topic Sheetcam revised post - please test
I have pushed a change that should allow run from line when using temporary materials.I'm encountering is that since the rain I keep getting power outages in the shed (not asscoiated with this) and when I restart and get everything aligned again, I can only start from the beginning of the job. Previously I would be able to enter a job at the beginning of any cut.
The following user(s) said Thank You: RNJFAB
- RNJFAB
- Thank you received: 59
13 Nov 2021 10:02 #226299
by RNJFAB
Replied by RNJFAB on topic Sheetcam revised post - please test
Snow & Phil,
Thank you again for going above and beyond to help me with this.
I have been using sheet cam since I started as Mach 3, was, well, kind of you know, less than great. So sheet cam was my settings and config and mach just moved the torch around.
I'm finding plasma & now QTPlasmaC are much more than Mach 3, and can handle a bit of what I was doing in sheet cam.
I will try and transition over to QTPlasmac for all my tooling as it will be much easier to change materials for the same job that way. Currently i have a fairly robust naming convention for all my cut files telling me total size and material thickness. both of these are no longer required with how awesome QT is.
I'll do the update tonight, but will also try and import tools sets from sheet cam into QT.
Thank again guys.
Cheers
Thank again guys.
Cheers
