7i96 Configuration Problems
06 Feb 2022 18:50 - 06 Feb 2022 18:50 #234148 by PCW
Replied by PCW on topic 7i96 Configuration Problems
Do you have a voltmeter?
Measuring the voltage across the torch-on signals will tell you the voltage
(and whether they are AC or DC)
Measuring the current across the torch-on leads with a DVM will tell you
the required current
Last edit: 06 Feb 2022 18:50 by PCW.
06 Feb 2022 19:35 #234158 by salem747
Replied by salem747 on topic 7i96 Configuration Problems
I do have a multimeter. So turn the power supply on and take a voltage across the pins?
06 Feb 2022 19:46 #234161 by PCW
Yes, and you can also measure the current if you meter measures
current but note that when you do this, it will turn on the torch...
The following user(s) said Thank You: salem747
06 Feb 2022 19:48 #234163 by salem747
Yeah that's what I was wondering, the meter will close the circuit. Right? So if I leave the torch unplugged it should maybe just show an error?
06 Feb 2022 23:39 #234197 by salem747
4.5a @ 12.4v for arc start
Nothing on OK to move but I assume that is an input to the plasma from the Mesa. Do I need the OK to move circuit?
07 Feb 2022 10:28 #234231 by rodw
Replied by rodw on topic 7i96 Configuration Problems
On the previous page you said you have an A80. Is that a Thermal Dynamics A80?
They are pretty straight forward. I have an A120
07 Feb 2022 15:34 - 07 Feb 2022 15:35 #234249 by salem747
Yes, a TD A80. Seems straight forward from the wiring diagram but absolutely no text on what it takes to be automated, ie voltage, contact style, etc for pins. I am assuming I use the outputs on the Mesa board but one person said that would fry something. The voltage on the arc start pins is 12 and the amperage is 4.5. I have the ok to move as an input on my Mesa ie one conductor in an input and the other in the common. I assume ok to move is the plasma telling the board that things are working in the power supply and it can start cutting.
Last edit: 07 Feb 2022 15:35 by salem747.
07 Feb 2022 15:40 #234251 by PCW
4.5A seems _VERY_ high
Are you sure it is not 4.5 mA?
I would expect "OK-to-Move" to be a dry contact closure
so requires an external power source
07 Feb 2022 15:44 #234252 by salem747
I will check again but I was just running it as a "short" through the meter. Ie pin to pin right through the meter.
07 Feb 2022 15:46 #234253 by salem747
That's the annoying thing about the documentation. If it's a dry contact that's great but what is the safe voltage range? Is it a dry contact? Not really sure!!! Just guessing. Srsly thermal dynamics?
Time to create page: 0.229 seconds
