LinuxCNC Forum
Toggle Navigation
Remember Me
Log in
Forgot Login?
Sign up
Index
Recent Topics
Search
www.linuxcnc.org
User Interfaces
Plasmac
7i96 Configuration Problems
Start
Prev
1
2
3
4
5
Next
End
1
2
3
4
5
PCW
Offline
Moderator
Thank you received: 5328
07 Feb 2022 18:06
#234265
by
PCW
Replied by
PCW
on topic
You can determine if the ok-to-move signal is a dry contact with (first)
a voltmeter to make sure no voltage is present, and then with an
Ohmmeter to check if you get a closed contact when ok-to-move
is true (that is when the arc is established)
Please
Log in
or
Create an account
to join the conversation.
Start
Prev
1
2
3
4
5
Next
End
1
2
3
4
5
Board Categories
LinuxCNC
- LinuxCNC Announcements
- General LinuxCNC Questions
- Installing LinuxCNC
- LinuxCNC Documents
Configuring LinuxCNC
- Configuration Tools
- - StepConf Wizard
- - PnCConf Wizard
- Basic Configuration
- Advanced Configuration
- - ClassicLadder
- - EtherCAT
- HAL
- - HAL Examples
User Interfaces
- AXIS
- Gmoccapy
- Plasmac
- pyVCP
- GladeVCP
- Other User Interfaces
- - PathPilot
- - QtPyVCP
- - Flex GUI
- Qtvcp
GCode and Part Programs
- G&M Codes
- O Codes (subroutines) and NGCGUI
- - Mill Library
- - Lathe Library
- - Plasma Library
- CAD CAM
- - Post Processors
- - - Fusion 360
- - - MasterCAM
- - - MecSoft
- - NativeCAM
Hardware & Machines
- Computers and Hardware
- Driver Boards
- CNC Machines
- - Milling Machines
- - Turning
- - Plasma & Laser
- Pick and Place
- Additive Manufacturing
Other Stuff
- Show Your Stuff
- Forum Questions
- User Exchange
- Off Topic and Test Posts
- - BeagleBone
International LinuxCNC Users
- Français
- Español
- Deutsch
- Other Languages
- - Russian
- - Polski
Moderators:
snowgoer540
User Interfaces
Plasmac
Time to create page: 0.283 seconds
Powered by
Kunena Forum
