QTvcp copy Error
3 years 4 months ago #273378 by Samas322
Replied by Samas322 on topic QTvcp copy Error
Oh nice! I already tried to make a user command file but wasnt able to load it in qtplasmac by adding USER_COMMAND_FILE = keyboard.py... in the display section of the .ini file. But i was able to create user_periodic.py and this file load perfectly but i tested for adding keyboard shortcuts but it never worked.. probably due to my low level programming skills..image missing /media/kunena/emoticons/dizzy.png but i will try it with your sample file! The only things im still not sure how to implement in this file is some timers...?
3 years 4 months ago #273379 by phillc54
Replied by phillc54 on topic QTvcp copy Error
You would need to import the timer, something like:
from PyQt5.QtCore import QTimer
The following user(s) said Thank You: Samas322
3 years 4 months ago #273383 by Samas322
Ok good i'll try this this afternoon! Thanks!
3 years 4 months ago - 3 years 4 months ago #273384 by Samas322
Also i noticed few bugs, when you do cut recovery and align with the laser then restart the cut the torch will probe down normaly then start and made a weird move in z and never start moving in xy. Even with the arc ok.
And some time when you do a framing with the laser the torch wont probe when you hit cycle start after the framing. You need to power off qtplasmac then power on to continue.
Last edit: 3 years 4 months ago by Samas322.
3 years 4 months ago #273398 by snowgoer540
Replied by snowgoer540 on topic QTvcp copy Error
Thanks for the bug reports. I've not noticed either of those, but step 1 for squishing bugs is being able to reproduce the, so I will try to reproduce them. Do you find that these happen consistently, or sporadically?
I ask because I've recently used cut recovery and align with the laser, and I didnt have any issues. So if you are getting it consistently can you either make another video, or give the exact steps to reproduce?
Same with the framing. I use framing every time I use my table and I've not run into that one yet.
I may reach out with more questions as I get time to look into it.
3 years 4 months ago #273400 by Samas322
For the cut recovery it append every time for me i will do a video when i get home. For the framing it did not happened consitently. I dont know if i did something different when it happened but i'll try to figure it out.
Time to create page: 0.087 seconds
