QTvcp copy Error
3 years 4 months ago #273508 by snowgoer540
Replied by snowgoer540 on topic QTvcp copy Error
Alright i just tested what you tell me to do and that worked perfectly well! So its just when im using the laser with the rev button that it happen.
Thank you for doing the testing on that, that really helps narrow down where to look.
To be clear, you had the laser on still, you just didnt use REV, correct?
3 years 4 months ago #273509 by Samas322
Replied by Samas322 on topic QTvcp copy Error
exact! but i did a test also with the laser using rev AND arrow key and it worked well also. so its only when i used the laser with rev but NO arrow key that the bug occur.
3 years 4 months ago #273513 by Samas322
i tried a lot of different things to reproduce the framing bug but it did not happened. I'll keep an eye on that and if i found anything i will tell you!
3 years 4 months ago #273672 by phillc54
Replied by phillc54 on topic QTvcp copy Error
Also i noticed few bugs, when you do cut recovery and align with the laser then restart the cut the torch will probe down normaly then start and made a weird move in z and never start moving in xy. Even with the arc ok.
A fix has been pushed for this. Thanks for the report.
The following user(s) said Thank You: Samas322
3 years 4 months ago #273674 by Samas322
Great thank you!image missing /media/kunena/emoticons/smile.png
Time to create page: 0.062 seconds
