QTvcp copy Error
3 years 4 months ago - 3 years 4 months ago #273426 by Samas322
Replied by Samas322 on topic QTvcp copy Error
The cut recovery bug that i tell you. The bug of framing did not happend but i'll try to replicate it and inform le you as soon as i found something!
Last edit: 3 years 4 months ago by Samas322.
3 years 4 months ago #273427 by tommylight
Replied by tommylight on topic QTvcp copy Error
Probably recovery code adding another M3 somewhere?
3 years 4 months ago - 3 years 4 months ago #273429 by snowgoer540
Replied by snowgoer540 on topic QTvcp copy Error
Interesting. I use cut recovery a lot, but I don’t think I ever press the REV button (with the laser). I’d you press cycle pause, and then just use the directional arrows to use a new touch off point, does it behave differently?
Last edit: 3 years 4 months ago by snowgoer540.
3 years 4 months ago #273436 by Samas322
I looked at the gcode file and nothing change in it when you do a recovery... it must be an internal code. I searched in the handler file but found nothing revelant so i think there must be a code file somewhere only for the cut recovery? I dont know much about the architecture of linuxcnc but i want to learn! If possible can you let me know if you found something please? Or at least just telling me where to search and maybe i could help you if i found something!image missing /media/kunena/emoticons/cheerful.png
3 years 4 months ago #273437 by Samas322
Snowgoer540 ok i'll try it tommorow!
3 years 4 months ago #273507 by Samas322
Alright i just tested what you tell me to do and that worked perfectly well! So its just when im using the laser with the rev button that it happen.
Time to create page: 0.070 seconds
