Feature Request: ramp piercing (aka moving piercing)
- Thank you received: 4149
26 Jan 2024 03:04 #291640
Replied by rodw on topic Feature Request: ramp piercing (aka moving piercing)
Very cool JoCo. More people are using QTplasmac on larger machines and adding in this functionality will allow them to getr more out of their machine
- caretech
- Thank you received: 26
28 Jan 2024 02:35 #291783
by caretech
Replied by caretech on topic Feature Request: ramp piercing (aka moving piercing)
Thank you Joco! I'll be checking this out for sure. Last time I cut 1" plate with my 85 I was doing edge starts where I was able, and drilling holes by hand for the rest.
The following user(s) said Thank You: rodw, Joco
- Joco
- Thank you received: 327
28 Jan 2024 08:36 #291790
by Joco
Replied by Joco on topic Feature Request: ramp piercing (aka moving piercing)
@caretech - any feed back on issues/refinements very welcome. Obviously get yourself a section of plate to experiment with settings to develop a recipe for your machine which will give you repeatable results.
Keen to see how you go so post pics of results.
Cheers - J.
Cheers - J.
- Joco
30 Jan 2024 23:46 #292028
by Joco
If anyone wants to use this capability on 2.9.x then I have a targeted repo that can pull the updated plasmac componet from and the needed m159 word, which is in the sim folder.
github.com/joco-nz/plasmac_pierce
You can either compile the component your self or pull the .so file which is compiled on an AMD64 arch.
Cheers - J.
Cheers - J.
- kworm
- Thank you received: 16
05 Jun 2025 14:16 #329741
by kworm
Replied by kworm on topic Feature Request: ramp piercing (aka moving piercing)
Sorry to post on a old topic but I wanted to see if this functionality was in qtplasmac in the 2.9.4 install or if you need to be running from the 2.10 master? Also, has anyone done moving piercing in Fusion360 CAM?
07 Jun 2025 21:14 #329899
You really should read the previous post.Sorry to post on a old topic but I wanted to see if this functionality was in qtplasmac in the 2.9.4 install or if you need to be running from the 2.10 master? Also, has anyone done moving piercing in Fusion360 CAM?
The following user(s) said Thank You: kworm
- kworm
07 Jun 2025 23:59 #329910
by kworm
Sorry, I did see the previous post but it's from a year and a half ago. I guess I should have asked if it had been merged into 2.9.4 and/or master.
08 Jun 2025 00:28 #329913
new features go into master branch (2.10) so this will never be in 2.9.4
Time to create page: 1.133 seconds
