- Thank you received: 5334
Servo Driver Plasma Retrofit
1 year 3 months ago #331245
Replied by PCW on topic Servo Driver Plasma Retrofit
I'm afraid ChatGPT will just be a time-sink here.
I suspect the easiest current path would be to make a pncconf QTPlasmac/THCAD configuration
for a 7I95T (This requires updating to the very latest LinuxCNC master as 7I95T support was just added
about 1 week ago) This configuration will match as far as encoders, inputs, and outputs go (though will show
more inputs than the 7I97T has, so just don't use any inputs beyond input 15)
When creating the 7I95T configuration, setup step/dir axis. and encoder feedback. This will create the
basic PID loop structure required for changing over to the 7I97T PWM/analog axis configuration.
When this is done, you will have a step/dir configuration for a 7I95T and QTPlasmac/THCAD.
Next you will need to change the card name in the ini file to "7i97".
then the created hal file will need to be edited to change the PID feedback input from stepgen
position to encoder position and the PID output from stepgen velocity to PWM value.
There are also enables and some PWM setup needed. I can help with these when you get a basic
hal file setup.
You can use this example of basic 7I97/7I97T PWM hal file setup:
hal file setup.
- kworm
- Thank you received: 16
1 year 3 months ago #331248
by kworm
Replied by kworm on topic Servo Driver Plasma Retrofit
I contributed the support for the 7i95t in pncconf. I don't have any 7i97s to try but if there is a similar card already supported in pncconf I could add support for it...I'm just not sure if it supports analog servos though.
I also did some initial work to add qtplasmac support to mesact but there are some fairly major internal assumptions about encoder 0 going to drive 0, etc. and I didn't want to make backwards compatible breaking changes without hearing from JT.
- Thank you received: 7491
1 year 3 months ago #331281
Replied by tommylight on topic Servo Driver Plasma Retrofit
No idea if this helps KWorm, but 7i97T (not aware of 7i97S) is the same functionally as 7i92 with 7i77, probably some IO pin names are different.
The following user(s) said Thank You: kworm
- kworm
1 year 3 months ago - 1 year 3 months ago #331289
by kworm
Thanks Tommy. The attached files will support the 7i97t. I created a config successfully but I don't have a card to test with so maybe the OP or someone can give it a try and let me know if it works. I can send in a pull request if it's good. This will only work with 2.10 master.
After updating to latest master just copy the attached private_data.py file to /usr/lib/python3/dist-packages/pncconf/ and the pncconf.py to /usr/bin/pncconf
I would suggest making a backup copies of the original files first just in case.
Last edit: 1 year 3 months ago by kworm. Reason: Add additional file to handle the inmux pin name for the 7i97t and revise instructions
- bentiggin
1 year 3 months ago #331948
by bentiggin
Replied by bentiggin on topic Servo Driver Plasma Retrofit
I just tried to create a config in pncconf for a 7i97t and I encountered an error.
Attached is a pic of the error.
I am a novice so I may be doing something wrong, I am barely sure I updated to 2.10.
1 year 3 months ago #331952
Can I send you a 7I97T?
Time to create page: 0.159 seconds
