- Thank you received: 7491
Servo Driver Plasma Retrofit
11 months 1 week ago #338815
Replied by tommylight on topic Servo Driver Plasma Retrofit
At the very top of your hal file, there is some symbol that does not belong there, seem like '
The following user(s) said Thank You: kn612
- kn612
- Thank you received: 4
11 months 1 week ago #338818
by kn612
Replied by kn612 on topic Servo Driver Plasma Retrofit
You guys rock. Thank you so much for pointing that out. I was editing hal with libre office instead of text editor. Added the line about offset mode and now the servos are quiet and don't move or jump when enabled.
11 months 1 week ago #338829
You are welcomed, always.
And as a general rule, edit machine files only with simple text editors, anything else will add special characters to the files making a mess.
Not much lately, to old !You guys rock.
- kn612
11 months 1 week ago #338844
by kn612
Great info as always. Thank you.
Setting up inputs now, getting an error on startup again related to inputs. It states input pins do not exist. Is this a common problem? Did I miss a simple step on configuring the 7i97t?
- Thank you received: 5334
11 months 1 week ago - 11 months 1 week ago #338845
Replied by PCW on topic Servo Driver Plasma Retrofit
That's an error in the configuration utility, you can fix it by globally replacing
"inm" with "inmux" in the hal file.
Last edit: 11 months 1 week ago by PCW.
11 months 1 week ago #338847
To replace the above, in the text editor hold down CTRL and press H, it will open two fields at the bottom, type inm in the top one and inmux on the bottom one, then click replace all, click save, do NOT close the text editor, first test and make sure the config works, then close.
Time to create page: 0.200 seconds
