Couple questions about QTPYVCP
18 Feb 2019 05:19 #126708 by KCJ
Replied by KCJ on topic Couple questions about QTPYVCP
Glad that got it working again!
KCJ
The following user(s) said Thank You: Leon82
18 Feb 2019 22:24 #126729 by Leon82
Replied by Leon82 on topic Couple questions about QTPYVCP
I added some buttons to save load and reload tools in the tool table, but its not saving the pocket number. it sets it to -1
18 Feb 2019 22:37 #126731 by KCJ
I noticed you don't have a P (pocket) column set in the tool table, that would explain why it is not being set. I guess for machines without a ATC P can always be the same as T, so maybe I should make P default to T unless specified otherwise...
KCJ
18 Feb 2019 23:07 #126732 by Leon82
KCJ
I thought that too so I pasted a table with p values and added back the p column. If I hit the save button it still overwrites it.
18 Feb 2019 23:19 - 18 Feb 2019 23:27 #126733 by Leon82
I fixed it.
The yml file didn't have it in there from when I added the snippet of code for moving the columns
Last edit: 18 Feb 2019 23:27 by Leon82.
18 Feb 2019 23:26 #126734 by KCJ
Yes, that text is specified in your YAML config file. To remove it delete the file_header_template option in the tooltable kwargs section.
You should also probably set the tooltable columns back to TPXYZR, and then use the tooltable widget's displayColumns property in designer to customize the visible columns and their order.
KCJ
19 Feb 2019 00:08 #126736 by Leon82
KCJ
Sounds good, thanks
22 Feb 2019 17:16 - 22 Feb 2019 17:20 #126924 by Leon82
How do you reset the spindle override?
Spindle.override.reset didn't work when I tried it
Last edit: 22 Feb 2019 17:20 by Leon82.
22 Feb 2019 17:45 #126928 by KCJ
I just testing `spindle.override.reset` and it seems to be working properly.
KCJ
22 Feb 2019 20:35 #126955 by Leon82
KCJ
Ok I'll double check
Moderators: KCJ, Lcvette
Time to create page: 0.337 seconds
