Couple questions about QTPYVCP
- KCJ
- Thank you received: 267
07 Dec 2019 13:12 #152243
by KCJ
Replied by KCJ on topic Couple questions about QTPYVCP
Gnevko, can please open a bug report for the Notify import error in the QtPyVCP repository?
- Gnevko
- Thank you received: 10
07 Dec 2019 14:20 - 07 Dec 2019 14:21 #152249
by Gnevko
Replied by Gnevko on topic Couple questions about QTPYVCP
Yes sir!
github.com/kcjengr/qtpyvcp/issues/28#issue-534406930
At the moment It's not possible to continue with GUI development - all qtpyvcp widgets are not available in the editor.
Last edit: 07 Dec 2019 14:21 by Gnevko.
The following user(s) said Thank You: KCJ
- Gnevko
07 Dec 2019 21:15 #152292
by Gnevko
Last update - the bug was fixed and now it works again as expected! Thank you, it's really the great team!
The following user(s) said Thank You: Leon82
- Leon82
- Thank you received: 79
07 Dec 2019 21:20 #152293
by Leon82
It must be the import patch it still won't load a machine config
Replied by Leon82 on topic Couple questions about QTPYVCP
- Leon82
08 Dec 2019 01:03 #152309
by Leon82
i found these in the home directory
it doesn't give much info
- Leon82
11 Dec 2019 01:19 - 11 Dec 2019 01:21 #152467
by Leon82
I got the email that it was updated So I upgraded and am still getting the same can't load vcp check the path error
Last edit: 11 Dec 2019 01:21 by Leon82.
- bevins
- Thank you received: 338
11 Dec 2019 01:48 #152468
by bevins
Where in Canada are you?
Replied by bevins on topic Couple questions about QTPYVCP
Oops, I may have introduced this bug trying to fix another without sufficient testing. Will check as soon as I get a chance. I'm freezing in Canada right now trying to fix a machine damaged in shipment...
- Leon82
11 Dec 2019 22:20 #152499
by Leon82
I got it to launch. I had to start Linux CNC and comment out my vcp display name.
In the qtpyvcp chooser I hit select file and navigated to my vcp folder in home directory.
I chose my config.yml and it launches.so i think something is going on with the path.
- KCJ
12 Dec 2019 03:54 #152516
by KCJ
Leon, my bad!
When i fixed another bug I changed some logic that made it fail if there was a folder with the same name as the VCP in the current working directory. I was unable to duplicate your problem at first because I usually launch QTPyVCP from within my dev directory so don't have any folders with the same name as a VCP. Should be fixed now, sorry about that!
- KCJ
12 Dec 2019 03:55 #152517
by KCJ
Montreal.
Montreal.
Moderators: KCJ, Lcvette
Time to create page: 0.208 seconds
