Couple questions about QTPYVCP
- KCJ
- Thank you received: 267
12 Mar 2019 18:50 #128461
by KCJ
Replied by KCJ on topic Couple questions about QTPYVCP
Ah, so you are editing the file in pluma, but when you reload after your changes the gcode edit widget does not update?
I probably need to add a file watcher so that if the file is edited outside of the VCP it will notice and reload with changes.
The following user(s) said Thank You: Leon82
- Leon82
- Thank you received: 79
12 Mar 2019 18:56 - 12 Mar 2019 18:56 #128462
by Leon82
Replied by Leon82 on topic Couple questions about QTPYVCP
I'll double check when I'm home
Yes, I did edit in pluma
Last edit: 12 Mar 2019 18:56 by Leon82.
The following user(s) said Thank You: KCJ
- Leon82
12 Mar 2019 19:49 - 12 Mar 2019 20:33 #128468
by Leon82
The widget is GcodeEditor. I don't see any other editor besides plain text edit
I played around with the plain text edit and looking at the probe basic ui and got it to display the program in the plain text edit.
I don't see any signals that would save the altered file
Last edit: 12 Mar 2019 20:33 by Leon82.
- Gnevko
- Thank you received: 10
03 Dec 2019 06:33 #151820
by Gnevko
Replied by Gnevko on topic Couple questions about QTPYVCP
one questions about the ToolTable Widget:
Is it possible to get the tool number (or let say generally the value from defined column(s)) from selected row?
The goal is to make manually tool change more comfortable (at least for me): select a tool in the tool table and press the button "Change Tool" (as MDIButton with M6 and G43 commands).
Thank you in advance!
- Leon82
03 Dec 2019 10:11 #151828
by Leon82
I'm not sure if you can get a specific signal like that from a click.
On mine I made a line of MDI buttons for t1m6 t2M6 etc
- Gnevko
03 Dec 2019 10:50 #151835
by Gnevko
It works in Probe_Basic GUI, but the solution is not very comfortable: you need at first write a tool number into the input field (VCPLineEdit) and then press M6 and G43 MDIButtons.
The MDI Property for M6 Button looks like that:
"T#<atc_tool_number_entry_box_2> M6"
atc_tool_number_entry_box_2 - is the name of input field (implemented as VCPLineEdit).
If the tool table widget could get the selected tool id (from a selected row) - that would be just great.
- Leon82
03 Dec 2019 10:54 #151836
by Leon82
What if you click the tool number on the atc graphic?
I wonder if you can make those MDI buttons and then they'd serve the function as tool number and if you click it it would change to that tool.
The button would be t2m6g43
- KCJ
05 Dec 2019 04:01 #152042
by KCJ
Yes it is! you can use the ToolTable.selectedRow() and ToolModel.toolDataFromRow() methods to get a dictionary of values for the currently selected tool in the table.
Here is a quick example:
I can provide a full working example if you would like.
Being able to load the currently selected tools is a great idea and should be standard feature. I will add a slot to the ToolTable widget for this. Thanks for the suggestion!
Cheers,
Kurt
current_row = tool_table.selectedRow()
if current_row != -1: #make sure a row is selected
tdata = tool_table.tool_model.toolDataFromRow(current_row)
print "Selected Tool Number:", tdata['T']
print "Selected Tool Diameter:", tdata['D']I can provide a full working example if you would like.
Cheers,
Kurt
- KCJ
05 Dec 2019 04:25 #152043
by KCJ
Done! You can connect a button to the new slot in designer and then you can use it to load the selected tool. I updated the examples/tool-table.ui file to show how.
github.com/kcjengr/qtpyvcp/commit/811e9d...9fb21df1c3ab2590037e
- Gnevko
05 Dec 2019 06:13 #152047
by Gnevko
Gut news, thank you for the quick response
Some other problems/ideas:
1) FileList Widget: my be I do something wrong (as usual actually
) but the FileList Widget in my own GUI (and also in Probe_Basic) doesn't wont to save the last selected folder. Each time I start LinuxCNC I need to do the same: go to the folder where my gcode files are stored. It take not much time, but each time ... it is not very bequem.
2) VCP Plot Widget: these are two types of zooming (at least in Probe_basic GUI): machine zoom and program zoom. The machine zoom works ok, but program zoom doesn't. It happens just nothing if I click on it. Expectation is: it should zoom the Plot Widget so that I can see let say the whole/all GCode paths (I hope you understand what I mean).
3) VCP Plot Widget "PAN" Button (again in Probe_basic) has general no functionality connected to it.
Moderators: KCJ, Lcvette
Time to create page: 0.191 seconds
