Installing LinuxCNC 2.10 And Probe Basic on Linux MX 21
3 years 5 months ago #271196 by mattdom142
Small detail
You can not have synaptic open and the terminal open at the same time.
The terminal dose not like synaptic open at the same time, it will lock processes and stop changes in the terminal.
3 years 5 months ago #271223 by tommylight
You can have as many terminals open as you like, just can not install anything while Synaptic is opened.
3 years 5 months ago #271234 by mattdom142
Got this error on step 12.
RROR: File "setup.py" not found. Directory cannot be installed in editable mode: /home/CNCMill/LinuxCNC_Install/qtpyvcp
(A "pyproject.toml" file was found, but editable mode currently requires a setup.py based build.)
not sure what to do.
3 years 5 months ago #271236 by Lcvette
how are you installing?
3 years 5 months ago #271238 by Lcvette
the instructions on the probebasic website for development installation need to be updated, use the instruction in the sticky section for editable mode. but things in that arena are changing frequently currently so we hope once we get the development 100% completely sorted to update the probebasic webpage installation instructions.note also that when using development mode from the sticky section you will need to build deb file and install for machine use applications.
3 years 5 months ago #271239 by mattdom142
I'm just using the terminal and following the instructions provided on this post. This is my first try.
Moderators: KCJ, Lcvette
Time to create page: 0.425 seconds
