- Thank you received: 7491
Only if that's where you have put it ....OP: I think you're missing some folder changes. Need to drop in to dev/linuxcnc/rip/src before the ./configure... command.
If you follow the instructions on the web site to get a git clone then you will end up with the Linuxcnc source in ~/linuxcnc-dev/src
Code:cd ~/linuxcnc-dev/src ./autogen.sh ./configure make sudo make setuid Is pretty much all I ever do. Several times an hour some days...
