Installing LinuxCNC 2.10 And Probe Basic on Linux MX 21
3 years 5 months ago #271240 by Lcvette
are you wanting to install for machine use or do you want to develop it? if for machine use you need to install the .deb version, and im not sure if that will work on that OS. currently xfce4 is the supported OS for qtpyvcp and probe basic. pip install no longer works on any version or OS as of Python 3.11 which is the currently used version. not something we are happy about but we must use the new venv method which isn't awesome. that is documented in thr sticky section, but that is for DEVELOPMENT work only!!!
so if you are dead set on using MX21, you are pretty much on your own.
if you want to follow the proven and supported method, it will just simply work!
3 years 5 months ago #271243 by mattdom142
hmm
Looks like a bit of an issue. If that's true I'm stuck. My machine (PC) is brand new and the hardware is not compatible with the older versions of Linux. Debian 10 buster is where I started and it failed to display anything because of driver issues. MX has exactly what I need to run my machine but if it has new python software and that is not compatible with Probe Basic then all I have is the default Linux CNC?
Which is ok but I had planned on using probe basic.
3 years 5 months ago #271245 by Lcvette
2.10 is the development version of linuxcnc, you should be on 2.9 ( also technically a development version but more stable. both are run on debian 12 which is also currently the development version although it has a release date now to be current in a few weeks. debian 12 with the non free firmware is most likely every bit as compatible as mx21.
3 years 5 months ago #271246 by mattdom142
Ok, I can give that a try and see if it works.
do you expect that to work with probe basic as it is or will it take time for probe basic to be compatible with debian 12?
3 years 5 months ago #271248 by Lcvette
kcjengr.github.io/probe_basic/quick_start.html#
probe basic is now only compatible for install with debian 12 as a standard practice. use the link above for the correct installation.
3 years 5 months ago #271255 by JPL
Chris, Just wanted you to know that I was looking at your home page and saw that your link to QtPyVCP ( qtpyvcp.kcjengr.com/ ) is leading to a 404 error. I think the correct link is www.qtpyvcp.com/
Moderators: KCJ, Lcvette
Time to create page: 0.461 seconds
