- Thank you received: 784
Found a small error.just for future reference, there is only ONE method of install, stop seeking work arounds and you will be better off. just report any issues here as was done and we will advise a fix or work around until we find any bugs causing an issue and repair them. Rodw means well, but is not current on the installation methods, his instruction was correct for the previous version install but not any longer which may be where you ran into an issue.
