Thank you. When I click on the the links in the instructions in that section (http://repository...) nothing happens. Is that correct?just download the 3 Deb files and the instructions in that drive folder.
typingCode:dpkg -i deb-name.deb installs a Deb file., There is a Linux shortcut where you can type enough of the file name to be unique and hit tab which auto complete the command for you. to paste into the terminal either right click or control_shift_V
Thank you. I tried the developer download and that works just fine. I used the instructions from smallmachineshopconcepts video on YT. Can I use that to run my machine? Or do I need to do a standard install to run my machine?use this links for qtpyvcp deb:
repository.qtpyvcp.com/repo/qtpyvcp-dev/...4871882e.dev_all.deb
use thise link for Probe Basic deb file:
repository.qtpyvcp.com/repo/probe-basic-...-cf74f74.dev_all.deb
