qtvcp issues
  • auto-mation-assist
  • auto-mation-assist's Avatar
  • Platinum Member
  • Platinum Member
11 Jan 2019 07:13 #123946 by auto-mation-assist
Replied by auto-mation-assist on topic qtvcp issues
You are right but I did do a make clean before compiling again.
  • Platinum Member
  • Platinum Member
11 Jan 2019 07:17 #123947 by auto-mation-assist
It could be a system issue system issue because I get the same result from 3 different linuxcnc installations that have qtvcp.
11 Jan 2019 07:24 #123948 by cmorley
Replied by cmorley on topic qtvcp issues
Is this work pushed to your repo - so i could test?
11 Jan 2019 07:37 #123949 by cmorley
I just recompiled on my system with no apparent problems running qtvcp or designer.
Chris M
  • Platinum Member
  • Platinum Member
11 Jan 2019 07:47 #123950 by auto-mation-assist
I did more checking and recall that I had a similar isue like this in the past relating to the links from:
/usr/lib/x86_64-linux-gnu/qt5/plugins/designer/python/qtvcp_plugin.py
I checked the link it it followed back to the correct file in:
/home/cnc/qtvcp-dev/lib/python/qtvcp/plugins/qtvcp_plugin.py
However that file is not executing. If I start designer -qt=5 without . ./scripts/rip-environment in /home/cnc/qtvcp-dev/ I get:
cnc@cnc-OptiPlex-9020 ~/qtvcp-dev $ designer -qt=5
File "/usr/lib/x86_64-linux-gnu/qt5/plugins/designer/python/qtvcp_plugin.py", line 22, in <module>
from qtvcp.plugins.simplewidgets_plugin import *
ImportError: No module named 'qtvcp'
Segmentation fault (core dumped)
cnc@cnc-OptiPlex-9020 ~/qtvcp-dev $ . ./scripts/rip-environment
So this is perhaps a privilege issue?
11 Jan 2019 07:53 #123951 by cmorley
If you don't use ./scripts/rip-environment, it's expected that qtvcp wouldn't be found.
That is what the script is for.
Does the screen it's self run?
11 Jan 2019 07:54 #123952 by cmorley
By screen I mean linuxcnc
  • Platinum Member
  • Platinum Member
11 Jan 2019 08:07 #123953 by auto-mation-assist
Yes linuxcnc runs fine with the 1xMill gui as normal. it seems to me from my test that after commenting out: from qtvcp.plugins.simplewidgets_plugin import * in qtvcp_plugin.py and it pick up the led file as the first one that I get the same error with it. So its finding the files it needs but does not like everything it runs into.
File "/usr/lib/x86_64-linux-gnu/qt5/plugins/designer/python/qtvcp_plugin.py", line 23, in <module>
from qtvcp.plugins.led_plugin import LEDPlugin
File "/home/cnc/qtvcp-dev/lib/python/qtvcp/plugins/led_plugin.py", line 5, in <module>
from qtvcp.widgets.led_widget import LED
File "/home/cnc/qtvcp-dev/lib/python/qtvcp/widgets/led_widget.py", line 21, in <module>
from qtvcp.widgets.widget_baseclass import _HalWidgetBase, hal
File "/home/cnc/qtvcp-dev/lib/python/qtvcp/widgets/widget_baseclass.py", line 19, in <module>
import hal
File "/home/cnc/qtvcp-dev/lib/python/hal.py", line 30, in <module>
import _hal
ImportError: /home/cnc/qtvcp-dev/lib/python/_hal.so: undefined symbol: _Py_ZeroStruct
  • Platinum Member
  • Platinum Member
11 Jan 2019 08:10 #123954 by auto-mation-assist
I will have to leave resolving this problem until tomorrow morning.
  • Platinum Member
  • Platinum Member
11 Jan 2019 08:12 #123955 by auto-mation-assist
Internet says it may be due to a python version issue
Time to create page: 0.391 seconds
