- Thank you received: 81
qtvcp issues
- auto-mation-assist
7 years 9 months ago #125425
by auto-mation-assist
Replied by auto-mation-assist on topic qtvcp issues
Yesterday I got the designer and linuxcnc working just fine on Mint 19.1 and could control all machine functions. Before this I could open the designer without a problem but after running linucnc for sever hours and then opening the designer I get the below message and opening the designer fails. this does not make much sense since none of the files listed in the error message were changed by me.
cnc@cnc1:~/qtvcp-dev$ . ./scripts/rip-environment
cnc@cnc1:~/qtvcp-dev$ designer -qt=5
qt5ct: using qt5ct plugin
qt5ct: D-Bus global menu: no
File "/usr/lib/x86_64-linux-gnu/qt5/plugins/designer/python/qtvcp_plugin.py", line 22, in <module>
from qtvcp.plugins.simplewidgets_plugin import *
File "/home/cnc/qtvcp-dev/lib/python/qtvcp/plugins/simplewidgets_plugin.py", line 5, in <module>
from qtvcp.widgets.simple_widgets import PushButton
File "/home/cnc/qtvcp-dev/lib/python/qtvcp/widgets/simple_widgets.py", line 17, in <module>
from qtvcp.widgets.widget_baseclass import _HalWidgetBase, _HalToggleBase, _HalSensitiveBase
File "/home/cnc/qtvcp-dev/lib/python/qtvcp/widgets/widget_baseclass.py", line 19, in <module>
import hal
File "/home/cnc/qtvcp-dev/lib/python/hal.py", line 30, in <module>
import _hal
ImportError: /home/cnc/qtvcp-dev/lib/python/_hal.so: undefined symbol: _Py_ZeroStruct
Segmentation fault (core dumped)
import hal
import _hal
- Thank you received: 2181
7 years 9 months ago #125454
Replied by cmorley on topic qtvcp issues
undefined symbol: _Py_ZeroStruct suggests a python version problem.
Does designer have a libpyqt5.so as well as the libpyqt5_py2.so?
If so and you don't use python3 widgets I would get rid of it and see if the problem goes away.
Chris M
Chris M
7 years 9 months ago #125473
Error message should be more friendly now.
The following user(s) said Thank You: auto-mation-assist
7 years 8 months ago #125576
I was just able to get QT5 reinstalled and back to normal. On this install using QT offline installer (1.5 GB) the gui buttons look a lot better than they did my original install of QT on Mint 19.1. That one I had installed from source.
I don't know where all these G codes are coming from:
this is all I find in my .ini file.
RS274NGC_STARTUP_CODE = G17 G20 G40 G43H0 G54 G64P0.005 G80 G90 G94 G97 M5 M9
7 years 8 months ago #125577
Not sure which ones you think are wrong, but it's probably because some are default even if you don't set them eg G90.1/G91.1. - looks like G91.1 is default.
Chris M
Chris M
7 years 6 months ago #130448
I have had to drop off my x1mill project for a while due to other commitments. My latest work is available from github but is still in need of changes.
github.com/auto-mation-assist/x1Mill_branch
The following user(s) said Thank You: KCJ
Time to create page: 0.907 seconds
