Error Messages
- phillc54
- Thank you received: 2100
04 Mar 2020 02:45 #159164
by phillc54
Error Messages was created by phillc54
I am getting error messages on startup and shutdown on the sample configs.
Startup:
Shutdown:
Bearing in mind that this is on a earlier RTAI build that Andy did here
Startup:
File "/usr/lib/python2.7/dist-packages/qtvcp/widgets/screen_options.py", line 253, in process_error
STATUS.emit('play-sound', '%s' % self.mchnMsg_sound_type)
AttributeError: 'ScreenOptions' object has no attribute 'mchnMsg_sound_type'Shutdown:
File "/usr/lib/python2.7/dist-packages/qtvcp/widgets/screen_options.py", line 263, in closeEvent
sound = self.shutdown_alert_sound_type
AttributeError: 'ScreenOptions' object has no attribute 'shutdown_alert_sound_type'Bearing in mind that this is on a earlier RTAI build that Andy did here
- Thank you received: 7504
04 Mar 2020 03:06 #159169
Replied by tommylight on topic Error Messages
Noticed that a while back, did not care much as i do not like startup and shutdown sounds. PTSD from to much windows.
- Thank you received: 2181
04 Mar 2020 03:11 #159170
Replied by cmorley on topic Error Messages
can you post the screenoptions.py file?
the line numbers don't jive with my current file.
Chris
Chris
- phillc54
04 Mar 2020 03:12 #159171
by phillc54
Replied by phillc54 on topic Error Messages
Haha, I am the same Tom, I don't go much on the sounds either but I am also not fond of error messages.
04 Mar 2020 03:12 #159172
It's easy to quiet it in the preference file.
- phillc54
04 Mar 2020 03:15 #159175
by phillc54
I was just concerned about the messages, I have never seen them before.
04 Mar 2020 03:26 #159177
Yes me too - otherwise the screen runs?
- phillc54
04 Mar 2020 03:33 #159178
by phillc54
Yep, it runs perfectly. I first thought I was missing a dependency but I can't see any reference to that so then I thought it may be something that has been fixed since then.
04 Mar 2020 03:36 #159179
I did do some work a while back on preference. - so one could eliminate the startup greeting.
maybe the system needs update.
- phillc54
04 Mar 2020 03:59 #159183
by phillc54
Sorry Chris I didn't see your request for screenoptions.py, I shouldn't try to do this on my phone...
I should add that this is on Buster and I get the same with blender and qtaxis.
Time to create page: 0.751 seconds
