Error Messages
18 Mar 2020 11:26 #160656 by ajsinfotech
Replied by ajsinfotech on topic Error Messages
Thanks Chris!
Sorry but no luck... again... :(
18 Mar 2020 11:28 - 18 Mar 2020 12:50 #160657 by ajsinfotech
Thanks Chris!
BTW, I'm trying to configure Qt Designer HAL plugins but it throws:
libEGL warning: DRI2: failed to authenticate
qt5ct: using qt5ct plugin
qt5ct: D-Bus global menu: no
  File "/home/pi/.designer/plugins/python/qtvcp_plugin.py", line 22, in <module>
    from qtvcp.plugins.simplewidgets_plugin import *
  File "/home/pi/linuxcnc/lib/python/qtvcp/plugins/simplewidgets_plugin.py", line 5, in <module>
    from qtvcp.widgets.simple_widgets import PushButton
  File "/home/pi/linuxcnc/lib/python/qtvcp/widgets/simple_widgets.py", line 17, in <module>
    from qtvcp.widgets.widget_baseclass import _HalWidgetBase, _HalToggleBase, _HalSensitiveBase
  File "/home/pi/linuxcnc/lib/python/qtvcp/widgets/widget_baseclass.py", line 19, in <module>
    import hal
  File "/home/pi/linuxcnc/lib/python/hal.py", line 30, in <module>
    import _hal
ImportError: /home/pi/linuxcnc/lib/python/_hal.so: undefined symbol: _Py_ZeroStruct
qt5ct: D-Bus system tray: no
libpng warning: iCCP: known incorrect sRGB profile
I try all libpyqt5_py2.so versions (qt5.5, qt5.7 & qt5.9), Qt Designer starts but fails to load HAL widgets.
Could it be an issue between python2 & python3 libraries?
I am using an RPi3 Raspbian Buster. With Raspbian Stretch HAL widgets loads fine.
It is not one of my best weeks, I think :S
Last edit: 18 Mar 2020 12:50 by ajsinfotech.
18 Mar 2020 20:16 #160699 by cmorley
Replied by cmorley on topic Error Messages
You may need to compile the libpyqt5_py2. Those versions were compiled with X86_64.
what version of qt is on rasberrypi buster?
The undefined error doesn't look to be qt related though _hal.s0 is the python library module to linuxcnc's HAL interface. Does any of the other screens run?
Chris
  • phillc54
  • phillc54's Avatar Topic Author
  • Platinum Member
  • Platinum Member
18 Mar 2020 23:13 #160706 by phillc54
Replied by phillc54 on topic Error Messages
Chris,
I ran up my Pi4 for a test run, it runs raspberry buster:
Linux pi4-1 4.19.71-rt24-v7l+ #1 SMP PREEMPT RT Tue Mar 17 18:23:13 AEDT 2020 armv7l GNU/Linux
Qt is version 5.11 and _hal.s0 would need to be compiled for armhf
There looks to be some issue with Qt and OpenGL, I get these errors on starting up QtAxis and Blender although they do load after OKing the error messages:
Warning: Spoiler!
There is no display in the Preview tab.
Manually resizing the screen causes a segmentation fault:
Warning: Spoiler!
Designer does load although of course there are no QTvcp widgets.
If you need any further testing let me know.
19 Mar 2020 00:58 #160711 by cmorley
Opengl issues - linuxcnc uses very old legacy opengl routines.
I'm not an opengl guy....
but hey does AXIS display show?
Chris
  • phillc54
  • Platinum Member
  • Platinum Member
19 Mar 2020 01:02 #160712 by phillc54
Yep, AXIS displays normally and GladCVP panels show OK as well.
19 Mar 2020 05:58 - 19 Mar 2020 06:11 #160723 by ajsinfotech
Qt 5.11.3
I'm not totally sure but in my previous installation (Stretch) Qt Designer HAL widgets loaded fine.
Sorry, but I was doing lots of tests so I decide to use Buster on my RPi3 just to keep all things paired with my RPi4.
I also chose Buster because of Qt packages already available for it. :blink:
Last edit: 19 Mar 2020 06:11 by ajsinfotech.
  • phillc54
  • Platinum Member
  • Platinum Member
19 Mar 2020 06:04 #160725 by phillc54
I see reports that Qt on Buster is compiled for OpenGL ES and not OpenGL Desktop. Maybe that causes the issue.
19 Mar 2020 06:06 - 19 Mar 2020 06:13 #160726 by ajsinfotech
Hi Phillc54! Thanks for joining!
So, what do you suggest I do/try?
Last edit: 19 Mar 2020 06:13 by ajsinfotech.
19 Mar 2020 06:08 - 19 Mar 2020 06:09 #160727 by ajsinfotech
Thanks Chris!
All run just fine, but Qt.
Last edit: 19 Mar 2020 06:09 by ajsinfotech.
Time to create page: 1.177 seconds
