Error Messages
- Thank you received: 2181
04 Mar 2020 04:10 #159184
Replied by cmorley on topic Error Messages
Yes that's a really old file. There was a problem with making the preference file and so some variables don't get initialized. It's fixed now.
Chris
Chris
- phillc54
- Thank you received: 2100
04 Mar 2020 04:12 #159185
by phillc54
Replied by phillc54 on topic Error Messages
OK, thanks. I might try to do a build on RTAI tomorrow.
05 Mar 2020 14:36 #159276
Replied by andypugh on topic Error Messages
I think that there is a stated issue with pcspkr during boot with that kernel.
- ajsinfotech
17 Mar 2020 12:41 - 17 Mar 2020 13:16 #160578
by ajsinfotech
Replied by ajsinfotech on topic Error Messages
Hi people!
I installed linuxcnc master from source on a RPi3 running Raspbian Buster. Almost all of the installation steps were taken from gnipsel.com/linuxcnc/uspace/rpi4-rt.html.
I tested almost all sim examples and ran fine. I mean whatever example inside axis, gmoccapy, gscreen, etc. But, when I try to run any example from the qtvcp_screen (eg: qtaxis) I get the following errors:
I also installed all Qt5 tools (Qt5 Assistant, Designer, Linguist & Creator) and all run fine. So I think there is no Qt missing package, though it could be possible there will be a conflicting one.
I was googling around but no luck.
Any idea?
Thanks!
task: main loop took 0.013536 seconds
task: main loop took 0.011252 seconds
task: main loop took 0.013171 seconds
libEGL warning: DRI2: failed to authenticate
task: main loop took 0.015964 seconds
task: main loop took 0.012418 seconds
task: main loop took 0.010137 seconds
task: main loop took 0.013779 seconds
task: main loop took 0.013827 seconds
task: main loop took 0.011125 seconds
task: main loop took 0.010002 seconds
qt5ct: using qt5ct plugin
[QTvcp][CRITICAL] Canceled from Error Dialog
Qtvcp encountered an error. The following information may be useful in troubleshooting:
LinuxCNC Version : 2.9.0~pre0
File "/home/pi/linuxcnc/bin/qtvcp", line 358, in <module>
APP = QTVCP()
File "/home/pi/linuxcnc/bin/qtvcp", line 80, in __init__
from qtvcp import qt_makepins, qt_makegui
File "/home/pi/linuxcnc/lib/python/qtvcp/qt_makepins.py", line 23, in <module>
from qtvcp.widgets.screen_options import ScreenOptions
File "/home/pi/linuxcnc/lib/python/qtvcp/widgets/screen_options.py", line 26, in <module>
from qtvcp.lib.notify import Notify
File "/home/pi/linuxcnc/lib/python/qtvcp/lib/notify.py", line 19, in <module>
sys_notify.init('notify')
File "/home/pi/linuxcnc/lib/python/qtvcp/lib/sys_notify.py", line 58, in init
proxy = bus.get_object(name, path)
File "/usr/lib/python2.7/dist-packages/dbus/bus.py", line 241, in get_object
follow_name_owner_changes=follow_name_owner_changes)
File "/usr/lib/python2.7/dist-packages/dbus/proxies.py", line 248, in __init__
self._named_service = conn.activate_name_owner(bus_name)
File "/usr/lib/python2.7/dist-packages/dbus/bus.py", line 180, in activate_name_owner
self.start_service_by_name(bus_name)
File "/usr/lib/python2.7/dist-packages/dbus/bus.py", line 278, in start_service_by_name
'su', (bus_name, flags)))
File "/usr/lib/python2.7/dist-packages/dbus/connection.py", line 651, in call_blocking
message, timeout)
dbus.exceptions.DBusException: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.Notifications was not provided by any .service files
Shutting down and cleaning up LinuxCNC...I also installed all Qt5 tools (Qt5 Assistant, Designer, Linguist & Creator) and all run fine. So I think there is no Qt missing package, though it could be possible there will be a conflicting one.
Any idea?
Thanks!
Last edit: 17 Mar 2020 13:16 by ajsinfotech.
17 Mar 2020 15:50 - 17 Mar 2020 15:50 #160593
Open the file /home/pi/linuxcnc/lib/python/qtvcp/lib/sys_notify.py
look for this code and add the return marked:If all goes well the screen should run but you won't have desktop notifications.
If you confirm this I will add a error trap to do this automatically
I'm not sure what the actual fix would be.
Chris
Chris
def init(app_name):
"""Initializes the DBus connection"""
global APP_NAME, DBUS_IFACE
APP_NAME = app_name
name = "org.freedesktop.Notifications"
path = "/org/freedesktop/Notifications"
interface = "org.freedesktop.Notifications"
mainloop = None
return # <- ADD THIS HERE
if DBusQtMainLoop is not None:
mainloop = DBusQtMainLoop(set_as_default=True)
bus = dbus.SessionBus(mainloop)
DBUS_IFACE = dbus.Interface(proxy, interface)
if mainloop is not None:
# We have a mainloop, so connect callbacks
DBUS_IFACE.connect_to_signal('ActionInvoked', _onActionInvoked)
DBUS_IFACE.connect_to_signal('NotificationClosed', _onNotificationClosed)
Chris
Chris
Last edit: 17 Mar 2020 15:50 by cmorley.
- ajsinfotech
17 Mar 2020 15:57 #160595
by ajsinfotech
Thanks Chris!
Sorry but no luck...
Now it throws this:
Now it throws this:
No option 'overlay_sound_type' in section: 'SCREEN_OPTIONS'
[QTvcp.QTVCP.WIDGETS.OVERLAY_WIDGET][DEBUG] last removed: <qtvcp.qt_makegui.VCPWindow object at 0x767c4260> (overlay_widget.py:64)
No option 'CalculatorDialog_play_sound' in section: 'DIALOG_OPTIONS'
No option 'CalculatorDialog_sound_type' in section: 'DIALOG_OPTIONS'
No option 'MachineLogDialog_play_sound' in section: 'DIALOG_OPTIONS'
No option 'MachineLogDialog_sound_type' in section: 'DIALOG_OPTIONS'
No option 'catch_errors' in section: 'SCREEN_OPTIONS'
No option 'desktop_notify' in section: 'SCREEN_OPTIONS'
No option 'shutdown_check' in section: 'SCREEN_OPTIONS'
No option 'sound_player_on' in section: 'SCREEN_OPTIONS'
No section: 'MCH_MSG_OPTIONS'
Adding section MCH_MSG_OPTIONS
No option 'mchnMsg_speak_errors' in section: 'MCH_MSG_OPTIONS'
No option 'mchnMsg_sound_type' in section: 'MCH_MSG_OPTIONS'
No section: 'USR_MSG_OPTIONS'
Adding section USR_MSG_OPTIONS
No option 'userMsg_sound_type' in section: 'USR_MSG_OPTIONS'
No option 'userMsg_use_focusOverlay' in section: 'USR_MSG_OPTIONS'
No section: 'SHUTDOWN_OPTIONS'
Adding section SHUTDOWN_OPTIONS
No option 'shutdown_alert_sound_type' in section: 'SHUTDOWN_OPTIONS'
No option 'shutdown_exit_sound_type' in section: 'SHUTDOWN_OPTIONS'
No option 'shutdown_msg_title' in section: 'SHUTDOWN_OPTIONS'
No option 'shutdown_msg_detail' in section: 'SHUTDOWN_OPTIONS'
No section: 'NOTIFY_OPTIONS'
Adding section NOTIFY_OPTIONS
No option 'notify_start_title' in section: 'NOTIFY_OPTIONS'
No option 'notify_start_detail' in section: 'NOTIFY_OPTIONS'
No option 'notify_start_timeout' in section: 'NOTIFY_OPTIONS'
[QTvcp.QTVCP.LIB.NOTIFY][WARNING] show_noficication error: (notify.py:41)
File "/home/pi/linuxcnc/lib/python/qtvcp/lib/notify.py", line 39, in notify
n = self.show_notification(title, message, icon, timeout)
File "/home/pi/linuxcnc/lib/python/qtvcp/lib/notify.py", line 82, in show_notification
n.show()
File "/home/pi/linuxcnc/lib/python/qtvcp/lib/sys_notify.py", line 118, in show
raise UninitializedError("You must call 'notify.init()' before 'notify.show()'")
UninitializedError: You must call 'notify.init()' before 'notify.show()'
Shutting down and cleaning up LinuxCNC...Please Log in or Create an account to join the conversation.
17 Mar 2020 16:04 #160596
Did the errror message dialog display or did it crash?
did you press cancel or ok? (try ok)
Chris
Chris
17 Mar 2020 16:07 #160597
same file:
def show(self):
if DBUS_IFACE is None:
"""Asks the notification server to show the notification"""
nid = DBUS_IFACE.Notify(APP_NAME,
self.id,
self.icon,
self.title,
self.body,
self._makeActionsList(),
self.hints,
self.timeout,
self.id = int(nid)
NOTIFICATIONS[self.id] = self
return True
18 Mar 2020 07:56 #160645
I pushed code to work around this problem. Hopefully that works till we figure out what the real problem is (but I don;t have a raspberrry pi so...)
Chris
Chris
- ajsinfotech
18 Mar 2020 11:23 - 18 Mar 2020 11:24 #160655
by ajsinfotech
Dialog display and then crashDid the errror message dialog display or did it crash?
Either way, ok nor cancel workdid you press cancel or ok? (try ok)
Last edit: 18 Mar 2020 11:24 by ajsinfotech.
Time to create page: 0.414 seconds
