- Thank you received: 96
Сustomization QTvcp
- hottabich
5 years 10 months ago #192253
by hottabich
Replied by hottabich on topic Сustomization QTvcp
Clicked action button spindle_up_action or spindle_down_action, start spindle, start fwd or revers. I think it's wrong. Your comment please.
- Thank you received: 2181
5 years 10 months ago #192261
Replied by cmorley on topic Сustomization QTvcp
That is how it's designed.
If the spindle is not running it starts, if it's running it changes speed.
Of course you could code the button to do something else
Chris
Chris
- hottabich
5 years 10 months ago - 5 years 10 months ago #192269
by hottabich
Thank you, I see!
Last edit: 5 years 10 months ago by hottabich.
5 years 10 months ago #192279
as it is now:
CCW always sets speed down, if the spindle is already running and CW always sets the speed up, if the spindle is already running.
I could see the argument for the button that starts the spindle always being the speed up button.
Chris
Chris
- hottabich
5 years 10 months ago - 5 years 10 months ago #192342
by hottabich
And please tell me how to programmatically disable the run in action button UP, Down function? This is for the safety of the car, I think so. Thanks for attention!
5 years 10 months ago - 5 years 10 months ago #192355
So this is the relevant code in action_button.py
it checks what spindle you wish to start (-1 means all spindles)
If the spindle is running it speeds them up.
If the spindle isn't running it starts it at the default spindle speed.
Here might be a function to add to the handler file to be called from a button.
You would need to use designer to connect a signal to it.
It assumes you only wish to speed up the spindle number 0
Chris
elif self.spindle_up:
if self.joint == -1:
a = 0
b = INFO.AVAILABLE_SPINDLES
else:
a = self.joint
b = self.joint +1
for i in range(a,b):
if STATUS.is_spindle_on(i):
ACTION.SET_SPINDLE_FASTER(i)
else:
ACTION.SET_SPINDLE_ROTATION(linuxcnc.SPINDLE_FORWARD,
INFO['DEFAULT_SPINDLE_{}_SPEED'.format(i)],i)
def spindle_faster(self, state):
if state:
ACTION.SET_SPINDLE_FASTER(0)
Chris
Last edit: 5 years 10 months ago by cmorley.
Time to create page: 0.676 seconds
