Сustomization QTvcp
5 years 10 months ago #191480 by hottabich
Replied by hottabich on topic Сustomization QTvcp
I am trying to add utilities from QtDrago-Master to QtDragon. Can you please tell me what I'm doing wrong?
5 years 10 months ago #191492 by cmorley
Replied by cmorley on topic Сustomization QTvcp
I's need more detail of the problem.
5 years 10 months ago #191495 by hottabich
Sorry, sorry. Utility widgets are not displayed, I did everything as in QtDragon-master. Here is a handler from it.
5 years 10 months ago #191554 by cmorley
Those utilities are not in master - they look like they came from Jim's github.
The possible problems of display are many.
You need to learn to trouble shoot more.
Things to check:
Is the ui file of the utility being found?
is the utility widget ever set to be shown or is it hidden?
is the function to install the utilities ever called?
If there is a difference between 2.8 and master try to pin point what the difference is.
try adding a pyqt widget instead of the utility widget; to try to see if it's the utility widget that has a problem or it's the code loading it.
etc.
I can help, if you narrow it down to a particular code or widget.
Chris
5 years 10 months ago #191560 by hottabich
I am sorry for disturbing you. The question has just been closed. Not mindfulness. Evenings are smarter morning.
Missed self.init_utils () I'm sorry.
5 years 10 months ago #191561 by cmorley
Oh great - I'm glad you figure it out!
I've certainly had mornings like that.
I don't mind helping - I just need details of the problem to focus my investigation.
I am curious about the calculator - qtvcp already has a calculator widget - what's different?
Chris
Time to create page: 0.633 seconds
