Сustomization QTvcp
6 years 1 month ago #183807 by hottabich
Replied by hottabich on topic Сustomization QTvcp
Hello! Please help me make a full screen in QtDragon. I'm out of
variant. The brain boils with confusion. Thanks!
6 years 1 month ago #183879 by cmorley
Replied by cmorley on topic Сustomization QTvcp
try this.
The problem was, the widgetswitcher pages did not have layouts set in them.
You can tell by the red circle-with-slash icon in the Object inspector list.
I set it up so any main tab can be 'full screen' rather then just the gcode graphics display.
You could change that if you don't like it.
Chris
6 years 1 month ago - 6 years 1 month ago #183935 by hottabich
There are no words for gratitude! Everything works as desired! I realized my mistake. After the alteration, you need to comment on these lines in qtdragon_postgui.hal
#net tool-change hal_manualtoolchange.change <= iocontrol.0.tool-change #net tool-changed hal_manualtoolchange.changed <= iocontrol.0.tool-changed #net tool-prep-number hal_manualtoolchange.number <= iocontrol.0.tool-prep-number
.What's wrong?
Here's a worker qtdragon (1024x768) in window x1Mill. In the images folder is missing probe_help.png (did not fit the file size). There are two widgets in the replace folder. Thanks again !!!
Last edit: 6 years 1 month ago by hottabich.
6 years 1 month ago #183939 by cmorley
make sure 'tool_dialog' is selected in the screenoptions widget's properties.
Other wise the HAL pins for the tool dialog is not made.
Chris
6 years 3 weeks ago #185381 by hottabich
Hello! I am eager to integrate the sim panel into a full hd interface. Please tell me how to register
eto in the handler or where to read. Thanks!
6 years 3 weeks ago #185403 by cmorley
Currently you can't combine separate panels (even qtvcp ones) unless you use the X11 embedding process which has a few limitations and warts.
The best way to incorporate the panels is to use designer to copy and paste the panel into the original design. Then if the panel has a handler file to move the relevant code into the dragon handler file.
The intended way was to have the jog panel float as it's just for testing.
You can see the idea with TOUCHY sim (though it use GLADEvcp)
Chris
Time to create page: 1.000 seconds
