- Thank you received: 2181
Сustomization QTvcp
6 years 5 months ago #167143
Replied by cmorley on topic Сustomization QTvcp
There is a signal from the gcode editor 'percentDone'
use the same process to connect it in designer to the percenetDone function in the handler file.
- hottabich
- Thank you received: 96
6 years 5 months ago #167144
by hottabich
Replied by hottabich on topic Сustomization QTvcp
Connected, everything works !!! Respect and respect to you!
- hottabich
6 years 5 months ago - 6 years 5 months ago #167653
by hottabich
Hello! Going back to NO_FORCE_HOMING = 1. File uploads without all homed and executed. Does not work offset origin and tool table requiring all homed. In axis, gmoccapy in this mode it all works. In qtpyvcp also works. In QtVCP it can be fixed?
Last edit: 6 years 5 months ago by hottabich.
6 years 5 months ago #167677
Should be fixed now.
Chris
Chris
- hottabich
6 years 5 months ago - 6 years 5 months ago #167701
by hottabich
Thank! Everything is working. Thanks to you, I realized my dream! I created macros return.ngc allowing after stopping the program to move the tool on the table and go back turn on the spindle at a given speed, and set
feed rate. For complete happiness is not enough RUN FROM HERE according to the algorithm given in the archive. I ate but lacked knowledge. Tell me please if it is possible and you will have a free minute.
6 years 5 months ago #167761
You can set spindle running in MDI and then run from line should keep that spindle setting.
I tried setting the feedrate in MDI but it didn't seem to work - it may be a linuxcnc bug.
You could write a function that sets the spindle with a MDI command then calls run-from-line.
Usually one selects the line in the gcode_display widget.
Please be specific about what doesn't work.
Chris
Chris
Time to create page: 0.414 seconds
