Сustomization QTvcp
6 years 5 months ago - 6 years 5 months ago #167811 by hottabich
Replied by hottabich on topic Сustomization QTvcp
Something with Designer. I can not change the name of the object. Sorry this is my problem.
Last edit: 6 years 5 months ago by hottabich.
6 years 5 months ago #167812 by cmorley
Replied by cmorley on topic Сustomization QTvcp
Do you have another object named the same in the screen?
The name is not important other then it must be the same in designer and the handler file.
You can use the default name if you like.
6 years 5 months ago #167813 by hottabich
Sorry this is my problem. Thank You!!!
6 years 5 months ago - 6 years 5 months ago #167824 by hottabich
I did it as in the screenshots. I can not register the line number. What's wrong?
6 years 5 months ago #167874 by cmorley
Oh wait looks like you have readonly checked on the line edit widget.
uncheck that property
6 years 5 months ago - 6 years 5 months ago #167885 by hottabich
Super!!! After pressing the Push Button, the LineEdit window should be cleared and the button will become inactive, this is necessary. There was an incomprehensible problem after stop the tool continues to move with the spindle switched off. With RunFromHere it is not connected, I turned it off. Thank! Only problems in linuxcnc2.9, in 2.8 they are not here.
Time to create page: 1.535 seconds
