- Thank you received: 96
Сustomization QTvcp
- hottabich
6 years 5 months ago - 6 years 5 months ago #167778
by hottabich
Replied by hottabich on topic Сustomization QTvcp
Everything works great. Please open the file from the archive return.ngc and you will see what it is for. File from G54 x0, y0, z0 returns tool to point program stop (the milling cutter has broken, it is necessary to clean it ....) sets the feedrate, starts the spindle at the set speed and lowers it after a pause Zxx tool. All data is written to the Macro mdi_touchy section immediately after stop. And after that you need to go from the break line (the line number remembers my interface in line-number.log). But looking for the right line is not soon. Now, if I could beat the ability to register the line number in the Line window. As an option, Setup From Here from the archive. But to implement it in Qtvcp will not work. Something like this. After the update, the load dialog does not close file after cancel the window of the file . Linuxcnc 2.9.0~pre0.2047
Last edit: 6 years 5 months ago by hottabich.
- Thank you received: 2181
6 years 5 months ago #167781
Replied by cmorley on topic Сustomization QTvcp
I'm having a bit of trouble understanding...
I think you mean you are getting the wrong line logged. Yes this is a known problem with linuxcnc - there is currently no work around.
Oh oops ! I'll fix that soon. Thanks.
Chris
Chris
- hottabich
6 years 5 months ago - 6 years 5 months ago #167785
by hottabich
Thank you for the attention! It’s really hard for me to communicate my messages with Google translator. Here is the macro and Run from here like mine in qtpyvcp. Very comfortable and very bistro to go from the line. The macro works in mdi touch.
6 years 5 months ago #167790
Yes I'm sure it is difficult to understand me too with Google translate.
How do you wish to enter the line number to start from?
Do you wish to enter it in editbox widget?
Your PyQtvcp example seems to have a box to enter the line number in.
Is that what you want?
Chris
Chris
- hottabich
6 years 5 months ago - 6 years 5 months ago #167806
by hottabich
Is that what you want? ---- YES! Yes - forum.linuxcnc.org/qtpyvcp/38017-qtpvcp-...around-run-from-line Or Yes - forum.linuxcnc.org/qtpyvcp/38131-qtpyvcp...-program-step-solved . Launch Qtdragon with my files from post # 167701 and you will see everything. Surprisingly, I understand you perfectly! Entering a line number takes too much time in large files.
6 years 5 months ago #167809
ok i think I understand now - sorry it took so long!
add a linedit widget - I'll call it runFromLineEdit
add a stateEnableGridLayout, set properties: is_on_status and is_idle_status
add a PushButton into the stateEnableGridLayout - I'll call it runFromLineButton
using Designer add the signal clicked() from the PushButton to the form calling function runFromLineClicked
in the handler file add under init_widgets(self):
in the handler file under #CALLBACKS FROM FORM#
Hopefully that should give you a line edit that you can only put numbers into and pressing the button will run the program from that line.
Chris
self.w.runFromLineEdit.setValidator( QtGui.QIntValidator())
def runFromLineClicked(self):
text = self.w.runFromLineEdit.text()
if text !='':
ACTION.RUN(line = int(text))
Chris
Time to create page: 0.881 seconds
