- Thank you received: 2181
Сustomization QTvcp
6 years 5 months ago #167072
Replied by cmorley on topic Сustomization QTvcp
Do you have a button that uses python command (added in designer) for loading a selected file from file_manager?
The function used to be .load()
try changing it to:
INSTANCE.w.file_manager._getPathActivated()
Currently there is no way to get the progress of file loading.
try changing it to:
- hottabich
- Thank you received: 96
6 years 5 months ago - 6 years 5 months ago #167073
by hottabich
Replied by hottabich on topic Сustomization QTvcp
Does not work. If you remove (w) there is no manager.
Last edit: 6 years 5 months ago by hottabich.
6 years 5 months ago #167074
What did you have originally?
INSTANCE.file_manager.load() ?
what ever you had change the .load() to ._getPathActivated()
i will fix this problem soon but this will work around it for now.
Chris
Chris
- hottabich
6 years 5 months ago #167075
by hottabich
INSTANCE.filemanager.load() it beat like that. Thanks for watching, wait.
6 years 5 months ago #167076
I'm looking at AXIS progress code but it's complicated and not well documented, not sure if it will make it into 2.8
6 years 5 months ago - 6 years 5 months ago #167093
Ok I pushed some work that makes it possible to get a percent signal from the graphics display.
You must connect a signal in designer from the graphics display to the form.
The signal is called percentLoaded
Then make a function in the handler to update your progressbar.
qtaxis shows an example.
You may also connect the signal directly to a progressbar in designer but you will have less control that way.
Last edit: 6 years 5 months ago by cmorley.
Time to create page: 0.318 seconds
